Old 07-22-2006, 11:29 AM   #1
Removing Non Paintable Caulk
Grabbed the wrong tub in the garage.
It is already dry. How can I remove it?
The paint is peeling up on the edges where it was used.
Please help!!!
TIA
davo420 is offline   Reply With Quote
Old 07-26-2006, 08:05 PM   #2
You could razor it out, being very careful not to damage anything or..........if its the paint just not holding, you could paint along it with a good acrylic bonding primer.once dry you can use other paint on top.
lxdollarsxl is offline   Reply With Quote
Old 07-26-2006, 08:58 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Razor blade, putty knife
Or primer with BIN (may need two coats) then paint
(use alcohol to remove oils from caulk)
slickshift is offline   Reply With Quote
Old 07-31-2006, 12:16 AM   #4
dang i thought i said that
Old 07-31-2006, 05:24 PM   #5
slickshift's Avatar
BIN is shellac
I've never tried it with an acrylic bonding primer
Old 08-01-2006, 11:53 PM   #6
np slick i suppose we all have our own ways and use different products.
Old 08-02-2006, 02:58 PM   #7
slickshift's Avatar
Definitely filed that one away to try sometime
Thanks for the tip
Old 08-16-2006, 08:28 PM   #8
SgtBaldy's Avatar
Everytime I see that stuff on peoples homes I am doing I go into their garage and make them throw away the stuff. Best to remove it.
SgtBaldy is offline   Reply With Quote
Removing Silicone Caulk... BillK40 Painting 36 12-07-2011 06:21 PM
Removing caulk? ysrchris Carpentry 8 03-05-2011 10:53 PM
Bathtub Caulk billinak Remodeling 17 05-27-2007 09:34 AM
Caulk Windows eric s General Discussion 2 11-26-2006 09:45 PM
