Removing Mold & Mildew From Dipped Cedar Siding - Painting - DIY Chatroom Home Improvement Forum
Old 07-06-2007, 09:47 AM   #1
I am painting a house right on the ocean. It has cedar shakes that we're pre-dipped for that Cape Cod look. Can I use a combination JOMAX and Bleach solution like I do normally on these shakes before I powerwash?
bmfay10 is offline   Reply With Quote
Old 07-06-2007, 01:09 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Yup
slickshift is offline   Reply With Quote
Old 07-06-2007, 01:11 PM   #3
slickshift's Avatar
...wait...are you re-painting/staining the shakes?
Old 07-06-2007, 04:12 PM   #4
No, Just trying to clean them up
Old 07-06-2007, 04:24 PM   #5
Guest
Guest
Posts: n/a
I'd use something based on Sodium Percarbonate, not Sodium Hypochlorite. Restore-a-deck is such a product.
Old 07-06-2007, 04:39 PM   #6
Is there a similar product that is available at paint store or home Improvement center?
Old 07-06-2007, 06:40 PM   #7
Guest
Guest
Posts: n/a
Wolman DeckBrite, probably something from Cabots though I haven't read their MSDS yet. Flood should have one too I believe.
Old 07-06-2007, 07:27 PM   #8
slickshift's Avatar
Yeah, if you are not painting/staining, don't use the Jomax/Bleach if you can help it
Wolman/Cabots/Flood should be good
Old 07-06-2007, 07:33 PM   #9
Great Advice. I'm really glad I asked. I love all of FLOOD's products, but didn't know they had a product more appropriate than JOmax for this job. Thanks a lot
Old 07-27-2011, 02:57 PM   #10
removing black mold from cedar siding
I'm going to be removing black mold from exterior cedar siding. I'm told oxygen bleach is best. What do you guys say.
hoptch is offline   Reply With Quote
Old 07-27-2011, 07:36 PM   #11
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
[QUOTE=hoptch;694884]I'm going to be removing black mold from exterior cedar siding. I'm told oxygen bleach is best. What do you guys say.[/QUOTIf
If you are just cleaning them then use a sodium percarbonate product which activates and acts like an oxygen bleach. Wet the substrate, apply the cleaner, use a nylon deck brush to scrub the surface, let the product dwell and then rinse using a power washer on low pressure and don't put the wand to close to the siding. Keep the substrate wet with the cleaner. If it dries then re apply cleaner.
If you are restaining then follow up with a brightner after cleaning.
If your re staining and the old stain is failed then strip it off using an alkiline stripper, but be carefull using strippers as they are caustic and the better ones will burn your skin. Follow up with netralizing and brightning using a blend of citric and oxlic acid.
housepaintingny is offline   Reply With Quote
revitalizing cedar siding Fat b Painting 1 04-30-2007 02:29 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
