-   -   Removing Mold & Mildew From Dipped Cedar Siding (http://www.diychatroom.com/f4/removing-mold-mildew-dipped-cedar-siding-9675/)
bmfay10 07-06-2007 08:47 AM
I am painting a house right on the ocean. It has cedar shakes that we're pre-dipped for that Cape Cod look. Can I use a combination JOMAX and Bleach solution like I do normally on these shakes before I powerwash?
slickshift 07-06-2007 12:09 PM
Yup
:thumbup1:
slickshift 07-06-2007 12:11 PM
...wait...are you re-painting/staining the shakes?
bmfay10 07-06-2007 03:12 PM
No, Just trying to clean them up
poppameth 07-06-2007 03:24 PM
I'd use something based on Sodium Percarbonate, not Sodium Hypochlorite. Restore-a-deck is such a product.
bmfay10 07-06-2007 03:39 PM
Is there a similar product that is available at paint store or home Improvement center?
poppameth 07-06-2007 05:40 PM
Wolman DeckBrite, probably something from Cabots though I haven't read their MSDS yet. Flood should have one too I believe.
slickshift 07-06-2007 06:27 PM
Yeah, if you are not painting/staining, don't use the Jomax/Bleach if you can help it
Wolman/Cabots/Flood should be good
bmfay10 07-06-2007 06:33 PM
Great Advice. I'm really glad I asked. I love all of FLOOD's products, but didn't know they had a product more appropriate than JOmax for this job. Thanks a lot
hoptch 07-27-2011 01:57 PM
removing black mold from cedar siding
I'm going to be removing black mold from exterior cedar siding. I'm told oxygen bleach is best. What do you guys say.
housepaintingny 07-27-2011 06:36 PM
[QUOTE=hoptch;694884]I'm going to be removing black mold from exterior cedar siding. I'm told oxygen bleach is best. What do you guys say.[/QUOTIf
If you are just cleaning them then use a sodium percarbonate product which activates and acts like an oxygen bleach. Wet the substrate, apply the cleaner, use a nylon deck brush to scrub the surface, let the product dwell and then rinse using a power washer on low pressure and don't put the wand to close to the siding. Keep the substrate wet with the cleaner. If it dries then re apply cleaner.
If you are restaining then follow up with a brightner after cleaning.
If your re staining and the old stain is failed then strip it off using an alkiline stripper, but be carefull using strippers as they are caustic and the better ones will burn your skin. Follow up with netralizing and brightning using a blend of citric and oxlic acid.
