Removing Lemon Pledge (!) From Substrate??? - Painting - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 04:45 PM   #1
Rewards Points: 188
Roommate tried to help scraping a window sill of old paint. He did a good job scraping down to the base layer of very old oil paint and some areas of raw wood. He then cleaned the whole area after scraping - old oil & raw wood - with Lemon Pledge spray!
I know this has wax and/or silicone in it and is the last thing on earth that should be used to clean the area.
How do I clean this Pledge off? There's a lot of it I can feel the slickness of the surface.
I do have TSP substitute.
I told him to scrape away a little more to try to scrape some of the Pledge contaminated surface off. This will be primed with an alkyd primer (Ben Moore #217 Underbody Primer).
Thanks for any help.
Lovegasoline is offline   Reply With Quote
Old 01-04-2010, 05:42 PM   #2
the Musigician
DangerMouse's Avatar
i'd drag the razor blade backwards and 'plane' as much of it as i could get off that way, then the TSP, some sanding....
man...i bet you weren't happy about that booboo.....
DM
Old 01-05-2010, 08:11 AM   #3
Too Short? Cut it Again!
Try good old fashioned mineral spirits and then TSP substitute.
Removing old grass with tiller? gante Landscaping & Lawn Care 36 05-08-2013 03:26 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
removing tree roots from sewer tile 4just1don Plumbing 4 09-10-2010 08:23 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
