Removing Drywall Dust After Sanding? - Painting - DIY Chatroom Home Improvement Forum
Old 04-14-2006, 10:21 PM   #1
Removing drywall dust after sanding?
We have 4 rooms with new drywall. After the finishers mudded and sanded the joints, there is a fine layer of dust over the drywall. What is the best way to remove this before painting the walls? I have tried a damp sponge and it just tends to smear the dust around.
ponchoman1 is offline   Reply With Quote
Old 04-15-2006, 07:38 AM   #2
TEXTURE REVIVAL
Dale's Avatar
Dust from drywall
Hi Ponchoman1
have you tried dry brushing the dust off the surface as it does tend to spread when wetted with a damp cloth
It is likely however that a small residue of dust will remain until it is painted
when you do paint this surface for the first time you must make sure that the emulsion or sealer is of a wet (watery) consistency so that this will have more of a chance of sinking through the dust & porous (taped & filled joints) surface which will make keying on the next coats of emulsion possible
It is also not adviced to use a silky (sheen) emulsion for the first coat
Roll out the first coat thinly with a lambs wool or symthetic paint roller, making sure that you spread it evenly and not leaving any runs or roller marks
Let this first coat dry completely before attempting the next
Please don't forget to wear a mask when dusting off
Hope this helps
Regards
Dale
Dale is offline   Reply With Quote
Old 04-15-2006, 08:10 AM   #3
Darylh's Avatar
I use a soft broam for the first cleanup( ceiling, walls,floors) then I use a soft paint brush for all the corners then I put a soft round brush on my shop vac.
Darylh is offline   Reply With Quote
Old 04-15-2006, 09:26 AM   #4
Thx for the advice. Brushing the dust off should go quicker too. I appreciate the help.
Old 04-16-2006, 11:46 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by ponchoman1
...there is a fine layer of dust over the drywall. What is the best way to remove this before painting the walls?
I use those dry swiffers on a stick
The fluffy ones
I have been using them for years
They are the painters best tool since the roller
slickshift is offline   Reply With Quote
Old 04-17-2006, 06:14 PM   #6
My two pence worth would also be to lightly sand down after first coat applied to knock off any small bits that you will get no matter how well you clean off the first time.
lxdollarsxl is offline   Reply With Quote
Old 10-13-2006, 07:33 PM   #7
Greetings--
I have used a HEPA filter in my shop vacum and its brush attachment. That seemed to get all the fine layer of dust off the walls (floors, ect too).
Piney is offline   Reply With Quote
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Drywall dust in floorboard crevices ponchoman1 Flooring 1 04-30-2006 02:19 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
Dustelss Power Sanding Systems MasterStrokes Tools 14 10-12-2005 04:51 PM
