Removing Deck Stain From Stucco - Painting - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 10:02 AM   #1
Question
Removing deck stain from stucco
I thought I would save some work by having my 21 year old nephew paint the deck with stain. Boy, was I wrong. Not only do I have to remove all the stain that he did, but I have to remove it from the stucco. The hardware store told me to use muriatic acid to remove the stain from the stucco, but that I would most likely have to then add the stucco back. So......any advice on removing the stain from the stucco?
bigalwood is offline   Reply With Quote
Old 04-01-2013, 10:26 AM   #2
Girl with a Hammer
yes, you will end up having to repaint the stucco. First you shuld just clean it well with bleach to lighten the stain. Then you will need to repaint over it.
dixongal is offline   Reply With Quote
Old 04-01-2013, 12:29 PM   #3
I doubt bleach will lighten stain, and I doubt muriatic acid will require redoing the stucco, if it will even remove the stain. I would at least try some muriatic in a small area as a test. I would also try blasting it with a pressure washer. In the future, don't try to cut corners or avoid cost, it only costs more.
Old 04-01-2013, 03:40 PM   #4
Rewards Points: 3,404
Muratic acid is what we used to clean our mixers,so yes it will do some damage to stucco,and a pressure washer with a small tip will remove some stucco also,depending on how much psi is involved
Can't you just repaint it??
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
joecaption (04-01-2013)
Old 04-01-2013, 03:46 PM   #5
Rewards Points: 13,250
Prime and paint.
Old 04-01-2013, 05:26 PM   #6
cdaniels's Avatar
Stucco probably soaked that stain up like a sponge.If all else fails,get a quart of paint matched to the stucco an try to touch it up.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 04-01-2013, 05:31 PM   #7
We see this on this site and any DIY site all the time. Most of the time it's how to get paint or stain off of vinyl siding.
Prevention is is the key.
How in the world do people get paint and stain 2' up on a wall?
Old 04-01-2013, 07:09 PM   #8
Why is everyone assuming the stucco is painted? Most stucco is not. Muriatic acid is only as strong as the mixture you make, which normally is one part acid/ten parts water for etching. It etches the surface. A weak mixture of it will not not remove the stucco. It's not the safest thing for a DIY to use, and I would use a pressure washer first to try to blast if off. Maybe brush some stripper or solvent on prior to soften it up. If you do use the muriatic, always, always, always, add acid to water, slowly, never add water to acid, and have a neutralizer handy. Be sure to read all the dos and don'ts of working with acids, or you could be sorry.
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
chrisn (04-02-2013), user1007 (04-02-2013)
Old 04-02-2013, 12:53 AM   #9
Too Short? Cut it Again!
Joe is right if it is not painted stucco. If it is painted stucco I would think a nice stain blocking primer is in someone's future?
Or you could just vinyl side over it all. Vinyl siding only works if you drywall or paint over wallpaper on the interior sides of the walls though.
The Following User Says Thank You to user1007 For This Useful Post:
jsheridan (04-02-2013)
Old 04-02-2013, 03:41 AM   #10
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Or you could just tear the wall down and re build it
The Following 2 Users Say Thank You to chrisn For This Useful Post:
jsheridan (04-02-2013), user1007 (04-02-2013)
Old 04-02-2013, 05:28 AM   #11
A girl with a hammer, not a brush, an apparent cement guy, and a general contractor. I'm guessing all the relevant forums were slow yesterday.
The Following User Says Thank You to jsheridan For This Useful Post:
cdaniels (04-02-2013)
Tags
deck stain , stain removal , stucco
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 07:32 PM
Gray stain question for kiln dried deck steuspeed Painting 7 09-29-2012 04:13 AM
has anyone used this deck stain? mklang Painting 4 08-06-2010 09:55 AM
Need advice on deck flashing, water stain Durt Ferguson General DIY Discussions 4 04-20-2010 06:09 PM
Deck Stain arrghHeadache Painting 1 03-22-2010 10:51 PM
