Removing Or Covering Paint On New Unpainted Rough Plaster - Painting - DIY Chatroom Home Improvement Forum
Old 06-06-2009, 12:05 AM   #1
removing or covering paint on new unpainted rough plaster
I have never had experience with new rough plaster. All of my experience has been with drywall and joint compound or older plaster that has been previously painted.
I am painting a new house that has had the walls and ceilings plastered. I used a masonry primer on the walls and the homeowner decided not to paint the ceilings at this point. We hit the ceiling once with our roller while painting the walls with masonry primer and once with SW Duration Matte finish wall paint.
What options do we have to fix our errors on the ceilings? Our first thought was to try spackle or some watered down joint compound to cover the paint and dab at it with an old brush to get it to blend in with the plaster. I think the spackle would look a little light but joint compound would be pretty close to the color of the unfinished plaster.
laakntna is offline   Reply With Quote
Old 06-06-2009, 06:23 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by laakntna
...the homeowner decided not to paint the ceilings at this point. We hit the ceiling once with our roller while painting the walls with masonry primer and once with SW Duration Matte finish wall paint.
None...sorry
Call the plasterers back for touch up...if possible...and pay them whatever they need
slickshift is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
