Removing A Coating From Concrete Patio. - Painting - DIY Chatroom Home Improvement Forum
Old 09-09-2013, 04:15 PM   #1
Removing a coating from concrete patio.
Hi quick question maybe someone could help. I have a 30sq ft concrete balcony/patio with a really beat up coating on it. It's a bit thicker than paint and has some grit in it. I bought some jasco paint & epoxy remover (gel) from Lowes. Put on one coat of it and it didn't phase the coating. Ended up doing 3 coats and waiting between each. It still barely phased the stuff. The patio is outside, and small so I'm looking for something super powerful to remove this stuff. Any ideas?
regtwelve is offline   Reply With Quote
Old 09-09-2013, 07:00 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
It sounds like you have a heavy duty epoxy coating that is failing. Considering that the epoxy remover you tried didn't work, diamond grinding might be a option to look at.
The machines can be rented for $200-$300 a day, and they are pretty easy to use. Doing it this way would have the added benefit of prepping the pad for whatever coating you use to re coat it with.
I have used diamond grinders to remove sealers from concrete in perpetration for epoxy, but never to remove epoxy itself.
Most SW stores rent the machines. They could tell you if it would be appropriate for your situation. I would imagine it would work...
Jmayspaint is offline   Reply With Quote
Old 09-09-2013, 07:42 PM   #3
Rewards Points: 5,974
If it's stuck that well can't you just coat over it?
Old 09-10-2013, 04:36 PM   #4
The paint is gouged uneven and 30 years old, I spent a considerable amount of time grinding and refinishing the metal railing around this patio, and don't want to skimp on making the patio look good/last long. I'm really just looking for the brand and type of remover that is stronger than the stuff at lowes. Thanks!
Old 09-10-2013, 09:03 PM   #5
Rewards Points: 1,016
I had a painter 'carpet' on my concrete patio, a rented high power pressure washer took it right off.
____________
Vince
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Concrete patio blocks the stucco weep screed..how to fix this? westernguy Concrete, Stone & Masonry 0 06-19-2012 05:59 PM
Enclosed porch over existing concrete patio? Pat the Rat Concrete, Stone & Masonry 2 06-10-2012 10:09 PM
Concrete patio control joint marriedmanw Building & Construction 1 07-29-2011 07:23 PM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
