Removed RV Striping - Painting - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 08:30 PM   #1
removed RV striping
I want to paint the stripes on the RV with a spray automotive paint. My problem is after scraping the vinyl off I am left with a sticky residue. I bought a spray adhesive remover that didn't budge it ,goof off, acetone, brake cleaner, soft scrub, I scraped as much off as I could. Ace has a couple more products too What would you recommend?/
rrambeau is offline   Reply With Quote
Old 09-05-2010, 08:56 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
I have used WD40 and it worked for me but it may not for you. It can't hurt to try though.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-05-2010, 10:12 PM   #3
Thanks Jim I have tried that but it didn't help. The stripes have been on there for more than a decade.
Removed plunger type drain assembly but bathtub still wont drain. Please help lydiarosestiles Plumbing 3 05-01-2010 11:59 AM
How to tell if all wallpaper glue is removed? CameraGuy Painting 11 04-04-2010 06:31 PM
Removed Chair Rail - Need to Patch Who Dey Painting 7 03-04-2010 01:43 PM
Can the top baffel on the A-coil be removed? key1cc HVAC 7 12-25-2008 09:09 AM
Do zinc strips prevent black algae AFTER algae removed? unclej Roofing/Siding 1 08-18-2008 05:29 PM
