Remove Wallpaper Or Paint Over Top? - Painting - DIY Chatroom Home Improvement Forum
Old 06-13-2013, 12:37 PM   #1
Rewards Points: 590
Remove wallpaper or paint over top?
Scenario: one layer of non-textured wallpaper in very good condition, no peeling or tears. Was applied in the late 80s or early 90s. Have already purchased water-based paint and primer, which means it could cause the paper to loosen down the road but on the other hand, removing the paper now could damage the paper on the drywall and require hours and hours of spackling in addition to the adhesive cleanup.
Paint over the wallpaper or remove it?
operagost is offline   Reply With Quote
Old 06-13-2013, 12:42 PM   #2
Rewards Points: 13,246
Remove it.
It's never a good idea to paint over wall paper.
It will make it far harder or near impossible to remove later.
RWolff (06-13-2013)
Old 06-13-2013, 01:14 PM   #3
Rewards Points: 590
Let's hope it's strippable; then it will be easy to pull it straight down. Any suggestions on ensuring it comes off smoothly, whatever kind it is?
Old 06-13-2013, 01:19 PM   #4
Removing wall paper is almost never easy.
Lay down a tarp to protect the floor.
I use hot water and a dash of liquid fabric softner.
Mist it down and let it soak in.
As your working keep it wet.
http://www.wallpaperstripper.net/
Old 06-13-2013, 01:20 PM   #5
Rewards Points: 346
I'd be tempted to paint over it! Removing it is such a PITA.
But Joe is right, remove it. Use lots of patience, take it slow, take breaks (otherwise you'll rush and damage the wallboard, been there-done that).
I have seen some painted over and you wouldn't know it.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 06-13-2013, 01:27 PM   #6
Rewards Points: 590
I guess I'll at least try a top corner to see if it's peelable or strippable before I decide. Supposedly with those, you only need to break out the water and sponges to clean up any adhesive or paper backing once all the paper is off.
Old 06-13-2013, 01:40 PM   #7
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Another option might be laying over new sheetrock and totally covering the mess and have a nice clean smooth fresh surface to work with, but this can be a lot of work too.
RWolff is offline   Reply With Quote
Old 06-13-2013, 03:21 PM   #8
Too Short? Cut it Again!
Nothing says "I am lazy and I don't really care about my home!" like painting over wallpaper does.
Read the many threads on wallpaper removal here. Use a tank sprayer and a wide drywall knife. Saturate small sections at a time to free the paste and then have at it.
Prime the stripped surface with Gardz to be safe. Skim coat if needed then prime the mud. Then paint.
The Following 3 Users Say Thank You to user1007 For This Useful Post:
chrisn (06-13-2013), Gymschu (06-13-2013), moorewarner (06-14-2013)
Old 06-13-2013, 03:31 PM   #9
Rewards Points: 590
I asked not because I'm lazy, but because there are several kinds of wallpaper as far as adhesion. Spraying it with water won't do any good if it's vinyl. We're also talking about my living room, in the middle of my house, with lots of furniture and built-in bookcases. Painting isn't a trivial process and repairing the drywall would not be straightforward. Besides, the work I recently did in my bathroom proves I am terrible at it.
Old 06-13-2013, 04:44 PM   #10
Sorry! I did not mean to suggest you were. I was just sharing the general reaction most around me have ever had to painted over wallpaper.
Hopefully if you have vinyl you can get under a corner and wet the paste holding it from there. Or even better, perhaps it will come off easier than you think if you can just get a grip on a corner of it. I do hope whoever put it up did not use a vinyl adhesive and there is no reason they would have unless sticking what you have to existing vinyl.
Old 06-13-2013, 05:44 PM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Just strip it
Never, ever, paint wallpaper, un less it is ABSOLUTLY necessary and it very rarely ever is.
http://www.wallpaperinstaller.com/wa...stripping.html
Old 06-13-2013, 06:56 PM   #12
ltd
Rewards Points: 536
Originally Posted by chrisn View Post
Just strip it
really, whats the big deal ?strip it
ltd is offline   Reply With Quote
Old 06-13-2013, 09:01 PM   #13
Painting Contractor CT
Rewards Points: 77
Post
Sometimes you could paint over wallpaper and it could look ok, but I suggest removing the wallpaper if you can. Removal requires time and patience, but you could always hire someone to help you with it.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 06-14-2013, 03:23 AM   #14
Carpenter/Rehabber
moorewarner's Avatar
Scoring the paper to help get water behind can help, especially if it's vinyl.
moorewarner is offline   Reply With Quote
Old 06-14-2013, 07:16 AM   #15
Jmayspaint's Avatar
Rewards Points: 534
About the only time I will consider painting paper is if its cheap paper hung over bare drywall.
It can bond so thoroughly with the Sheetrock paper, that taking it off inevitably damages the walls.
If I'm trying to make it appear to be a smooth wall instead of 'painted wallpaper, it takes as much labor to prep it as it would to strip 'strip able' paper. So don't not strip to save dry wall work. I treat the paper seams like dry wall joints, - tape. Unless you want painted wallpaper.nbd.
Try to pull the face of the paper off. It it comes off in sheets at all, it would probably be easier to strip it. If it comes off in little pieces or not at all, it might be 'hyper bonded to the Sheetrock paper.
Would like to hear of any tricks to remove paper in this condition. Soaking in chems or water always seems to break the bond in the wrong place and really damage the rock. I don't know if this qualifies as 'having to' paint the paper, sometimes it seems like it to me.
Ran into this recently in a college office building. Painting it this time wasn't an option, it was textured commercial vinyl.
The pic doesn't really do justice to the amount of wall damage. After repeated, lengthy soakings this area took about 16 man hrs to strip. And still have to fix the drywall.
Blows my mind that people will hang on bare rock, especially commercial. I see this a lot around here though, not even surprised by it anymore.
Jmayspaint is online now   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Remove peeling paint? hyunelan2 Flooring 11 01-13-2011 04:59 PM
paint over wallpaper glue? drewhart Painting 5 11-04-2009 04:18 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
