Old 11-05-2009, 12:12 PM   #1
Default Remove paint from hinges on cabinet
Problem: The people who owned the house before we did painted over the hinges on the bathroom cabinets. I cannot unscrew the hinges because of the paint. What can I use to get the paint off the hinges -- so I can get the hinges off the cabinets.
I much prefer to use something natural as I have allergies and try to avoid harsh chemicals.
I'd appreciate any suggestions.
Thank you.
debpie is offline   Reply With Quote
Old 11-05-2009, 12:53 PM   #2
ArmchairDIY's Avatar
Use a small screwdriver or a knife tip to clean out the screws. Then remove the hinges and scrub them with a scotch brite pad. That is the least caustic method.
Option 2 would be to clean them carefully with Goof Off or lacquer thinner. Stinky, but effective.
"It looked good on paper, but paper is funny that way"
ArmchairDIY
ArmchairDIY is offline   Reply With Quote
Old 11-05-2009, 01:34 PM   #3
Assuming you plan to do something with the cabinets too? Use one of the new gel paint strippers. Otherwise, as suggested, use sharp tools to get to the screw head. There is nothing more dangerous than a tool that is dull though so do not compromise.
sdsester is offline   Reply With Quote
Old 11-09-2009, 02:09 AM   #4
If you have trouble unscrewing the screws, scrape out the paint and put a driver bit in to match the screw head and then get a socket to fit the driver head and ratchet it off.
No need to thank me .
nerd_flanders is offline   Reply With Quote
More On This Topic
Hello. My name is Grady Johnson and I'm a professional painter. Today I represent Expert Village.com. Now it's time to paint the base of the cabinets. Now today we've chosen to paint the base of the cabinets the same color as our walls and our ceiling... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Hi! I'm Betty Ingham speaking on behalf of Expert Village. Even though we did most of the work on this house ourselves, we were on a limited budget because of what we had to do was just so massive because we had to replace floors and walls and fireplaces... Read More »
Anyone in real estate will tell you that money invested in the construction or remodeling of a bathroom will be money in your pocket when it comes time to sell the house. There are lots of choices to make and choosing the right bathroom vanity can make... Read More »
Hi! I'm Betty Ingham and I am speaking on behalf of Expert Village and I would like to talk to you today about restoring an old Victorian home. The sink in here was in very very bad shape. We took it out and on the bath of it, we found 1920 so I'm sure... Read More »
Remove bedroom carpet & paint the floor?? munsonfamily Flooring 3 07-20-2009 05:03 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 01:04 AM
Help! Can't remove old hinges hardware from kitchen cabinets. sabrosonics Remodeling 1 03-08-2008 04:29 PM
Need ideas for cabinet hinges. wfischer Remodeling 10 01-12-2008 07:02 PM
How to remove paint from brick beezee3 Remodeling 2 12-28-2005 03:38 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
