Old 07-16-2009, 11:31 AM   #1
Remove dried paint from wood baseboards
I got Kilz and paint on baseboards. Is there a way to remove this without replacing the boards?
dunavantc is offline   Reply With Quote
Old 07-16-2009, 12:40 PM   #2
Xtreme DIY'r
You want to strip all the paint off?
Or you spilled/overpainted or have some drops you need to clean off?
I take the trim off & use a heat gun outside whenever possible
Inside I only strip paint when I can open the windows & use a fan
Old 07-16-2009, 03:54 PM   #3
General Contractor
If it is a small amount try goof off. Works pretty well but be careful not to to rub the trim finish off. You can also try motsenbocker's lift off 5 it works pretty well also.
ARI001 is offline   Reply With Quote
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
How to remove paint from brick beezee3 Remodeling 2 12-28-2005 02:38 AM
