-   -   Remove dried paint from wood baseboards (http://www.diychatroom.com/f4/remove-dried-paint-wood-baseboards-48975/)
dunavantc 07-16-2009 10:31 AM
I got Kilz and paint on baseboards. Is there a way to remove this without replacing the boards?
Scuba_Dave 07-16-2009 11:40 AM
You want to strip all the paint off?
Or you spilled/overpainted or have some drops you need to clean off?
I take the trim off & use a heat gun outside whenever possible
Inside I only strip paint when I can open the windows & use a fan
ARI001 07-16-2009 02:54 PM
If it is a small amount try goof off. Works pretty well but be careful not to to rub the trim finish off. You can also try motsenbocker's lift off 5 it works pretty well also.
