Old 06-09-2012, 06:02 PM   #1
removal of rust on an old cast iron tub
how do I remove rust from an old cast iron tub...all i want to do is display it in my shop and I would like to remove the rust on the outside of the tub then paint it
lprome is offline   Reply With Quote
Old 06-09-2012, 06:11 PM   #2
Gymschu's Avatar
If it's just light rust, some steel wool may do the trick. If it's fairly heavy rust you can use some sandpaper or a wire wheel disc on your drill to take it off.
Old 06-09-2012, 06:15 PM   #3
Remove the rust, fill in the pitting with bondo then spray with rusty metal primer (it also comes in gray not just a redish color) then epoxy or enamel paint.
Rust removal from cast iron tub Jupe Blue General Discussion 4 05-08-2011 10:13 AM
removing rust from a vintage painted cast iron doorstop Margo Painting 6 03-08-2011 04:22 PM
Remove Rust from Cast Iron Bed Rails cpalmer67 General Discussion 8 07-24-2009 03:25 PM
remove rust cast iron tub workingirl General Discussion 13 08-23-2008 03:41 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
