Removal Of Acrylic Paint From Enamel - Painting - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 10:34 AM   #1
Removal of acrylic paint from enamel
It looks like the previous owner of my house, painted over an enamel paint, with acrylic, on my bathroom ceiling. It is now cracking, and peeling. What's the best, and easiest ,way to remove the acrylic paint ?
brianfbruce is offline   Reply With Quote
Old 03-05-2011, 11:00 AM   #2
It sounds like damage from steam. Does it have a shattered look and small flakes peeling away?
Old 03-05-2011, 11:04 AM   #3
Yes, it does. First it cracks, then it peels. I believe it is caused by steam.
Old 03-05-2011, 11:20 AM   #4
Scrape off the loose paint and sand, use 80 or 100 grit paper, dust off the surfaces. Prime the areas, spackle, sand, then prime again. Use a finish that is at least a satin or go with Zinsser Perma-White or Ben Moore Bath and Spa, both dedicated bath paints designed for steamy environments. Good Luck!
Old 03-05-2011, 10:54 PM   #5
Faron79's Avatar
Rewards Points: 260
Follow JS's instructions here!
All existing junk has to be removed.
* Ideally, sand the whole ceiling when the alligatored chips are gone.
* Remove all dust.
* Then....JS's instructions!
* Any paint with a sheen is OK too though. Eggshell is OK, but a Satin would be better here, ESPECIALLY if no fan at all.
Also very important...Is there an effective bath-fan in there??
BTW...the word "Enamel" doesn't mean anything...it's just a marketing buzzword. In the 50's & 60's, it implied OIL-based paints. Then, when Latexes became more prevalent, the word "Enamel" was trotted-out to highlight this "New" paint!
>>> All Latex paints are varying quality levels of Acrylic Resins.
Faron
Faron79 is offline   Reply With Quote
The Following User Says Thank You to Faron79 For This Useful Post:
jsheridan (03-05-2011)
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Oil-based paint vs. 100% Acrylic paint: which one more durable? ohman Painting 11 07-03-2009 12:46 PM
Paint removal from concrete in basement ridofpaint Painting 3 04-06-2009 08:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
