Old 04-14-2012, 11:17 AM   #1
Remedy for peeling cracking metal doors
Hello,
I own a storage facility with roll-up metal doors approximately 15 years old. The paint is cracking, peeling and oxidizing badly and I want to get a fresh look on them without the expense of door replacement.
Two years ago I used a product Everbrite which was first applied by:
- pressure washing the doors
- acid wash to remove oxidation
- sanding by hand to remove cracking paint
- then applied clear Everbrite product
Today, the doors are peeling incrediably bad. Wanted to ask you professionals what prep work and products /steps to get my doors looking like new! I'm not sure what to use - oil based/latex etc. Remedies?
thanks,
DP
Dpowell is offline   Reply With Quote
Old 04-14-2012, 05:42 PM   #2
Painting Company, NY
housepaintingny's Avatar
Wash them, scrape and sand any loose, flaking, cracking paint off, you can bondo any bad areas, apply a product such as Sherwin Williams Procryl primer to any bare metal (has rust inhibitors) then apply Sherwin Williams DTM water bourne acrylic. Your better off using a water bourne over an oil, as it will flex more with the expansion and contraction of the metal and retain color better.
housepaintingny is offline   Reply With Quote
Voltage in the Shower Deacon98 Electrical 32 01-19-2012 05:14 PM
Multi rib metal roof on double wide...static vents wpilotm Roofing 0 09-10-2011 04:51 PM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
painting metal doors pjm Painting 5 06-04-2008 10:55 AM
Mystery Metal Door Jams Risa Building & Construction 4 04-27-2007 12:19 PM
