Remask After Primer? - Painting - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 04:53 PM   #1
Rewards Points: 337
Remask after primer?
I am painting a sliding glass door Panel, just sprayed the primer yesterday, should I pull the tape off the glass and remark before spraying the paint? Perhaps a basic question but I did not know if it really matters.
titan7 is offline   Reply With Quote
Old 04-29-2013, 04:57 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
No need if it is still holding on good
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-29-2013, 04:58 PM   #3
Too Short? Cut it Again!
Unless the mask has lifted, crinkled, torn or failed there is no need to replace it.
You should cut along the frame with a sharp razor blade before peeling it loose when you are done though.
Old 04-29-2013, 05:00 PM   #4
Mr. Paint's Avatar
Use 3M 2090 Blue Tape the next time you have to tape glass. It will come off after several weeks of UV exposure.
For now, continue with wahat you have, but don't put the finish job off too long.
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
Old 04-29-2013, 06:26 PM   #5
Rewards Points: 337
I can't paint it until this weekend. I used te green frog tape
Old 04-29-2013, 06:53 PM   #6
Tried the stuff recently but was not wowed. Package says you are good for 21 days and 7 in direct sunlight with the stuff though.
Old 04-29-2013, 07:57 PM   #7
Rewards Points: 337
Then I should be gtg as the door is in the garage out of the sun. I work during the wk I can't set up the booth in the garage and paint during the week as I get home at 6pm
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
