Rehanging Painted Cabinet Doors - Painting - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 06:59 AM   #1
Rehanging painted cabinet doors
Not sure if this is the category I should use, but I have removed my cabinet doors and hinges to paint. When I rehung, a couple of the doors hit wood and will not close. I presume it means a hinge is slightly bent? Is there an easy way to find which hinges should be moved where? They fit before I took them off.
ozgal is offline   Reply With Quote
Old 04-09-2013, 07:04 AM   #2
Rewards Points: 13,446
Let me guess, you did not mark the doors so you now have no idea which one went where.
Often that's the problum.
Old 04-09-2013, 07:42 AM   #3
The cabinet doors were marked and are in the right place.
Old 04-09-2013, 07:52 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
Did you also mark the hinges and put them in the same place?
This is not unusual. Remounting doors can be very time consuming. Many hinges have no adjustment, and over time the get tweeked into position, and when you remove them, you have messsed up a very sensitive situation.
Playing with the hinges, and screws and how tight / loose etc. Not an easy thing to do, yet explain here.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ozgal (04-09-2013)
Old 04-09-2013, 07:59 AM   #5
Hinges are not adjustable, and no, I didn't mark them. That never even occurred to me...until I put doors back on. Just was hoping there would be an easy way to find out which hinges are out of kilter. Thanks.
Old 04-09-2013, 07:59 AM   #6
What style hindges are they?
http://www.bing.com/images/search?q=...nges&FORM=IGRE
ozgal (04-09-2013)
Old 04-09-2013, 09:08 AM   #7
Old 04-09-2013, 11:31 AM   #8
Hi, ozgal
I may be stating the obvious here, but...those hinge types should fit into slots on the faceframe and doors. Loosen the screws just a bit, adjust the hinge very slightly back and forth (horizontal movement) in the slot(s), re-tighten the screws, and check the new fit. Repeat until you get what you need.
This can be time consuming, and takes patience, but you should be able to get them where you want them (most of them, anyway). You may have to spring for a couple new hinges to replace any that have tweaked over time.
As joecaption noted, this is a valuable lesson in marking each hinge to its place on each door, and each door to its respective opening when taking everything apart.
Good luck! You can do this.
clambake6 is offline   Reply With Quote
The Following User Says Thank You to clambake6 For This Useful Post:
ozgal (04-09-2013)
Old 04-09-2013, 01:20 PM   #9
I may have selected the wrong hinge picture. There is no slot, and no adjustments. There are really only 2 doors that are off kilter, so maybe if I concentrate on those 4 hinges I can figure that out. Just didn't want to spend the time taking them off and putting them back on if there was an easier way. Thanks for your input.
Old 04-09-2013, 01:34 PM   #10
Ah, yes...now that I look more closely at that hinge photo I can see that the small metal plates which would fit into the slots are missing...which explains why you don't have any slots on the doors or faceframes...
Veneering old cabinet doors sillycat41 Kitchen & Bath Remodeling 2 06-10-2012 10:23 AM
How do I paint Cabinet Trim to Match Stained Doors? Mjakester Painting 2 03-31-2012 06:09 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 10:35 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
