Register Fan Is Rusty - Painting - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 04:14 PM   #1
Question
Register Fan is rusty
I have a ceiling Register Fan but 1/4 of the fan is rusty so Which spray will I buy either lightly grey glossy and the white glossy?
surfbu is offline   Reply With Quote
Old 09-15-2013, 04:39 PM   #2
Gymschu's Avatar
Rewards Points: 838
Remove it from the wall, clean it, sand off the rust, remove any dust, and spray several coats of white (rattle can) spray paint on it.....done!
Krylon, RustOleum, either one is fine. Gloss is best for those kind of registers.
Old 09-15-2013, 04:42 PM   #3
What does rattle can mean?
Old 09-15-2013, 04:46 PM   #4
Gymschu's Avatar
Rewards Points: 838
This.
Old 09-15-2013, 05:02 PM   #5
Old 09-15-2013, 06:18 PM   #6
Rewards Points: 1,258
There is a reason for the rust and while the register is down possibly the cause of moisture in that area can be determined. With more pictures at that disassembled point possibly someone can see what the culprit is.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Gymschu (09-15-2013)
Adding new register via tee off existing register tpanc13 HVAC 12 06-30-2010 12:04 PM
How to attach ceiling register to duct? adrianm HVAC 6 03-25-2010 07:29 AM
Extra wall register in bedroom: seal up or relocate? pmoe HVAC 5 12-08-2008 09:57 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 05:26 AM
Molding over heat register patrickosu Remodeling 4 02-15-2008 11:07 PM
