Refinishing Wood Cathedral Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 09-13-2013, 03:47 PM   #1
I have a 1965 Eichler-style house with about 1500 sq feet of exposed softwood V-groove cathedral ceiling that I woud like to refinish. The stain looks pretty thin and easy to remove in most rooms, with only one room having been refinished with polyurethane.
Sandblasting or walnut blasting will leave a raised grain so I'm wondering if anyone has tried this followed by an orbital sander to smooth the surface.
Anyone use a Makita Brush Sander? A mop sander?
Any other ideas that will leave the surface nearly as smooth as the existing planed surface? The house has been in my family for 40 years so I prefer to keep it close to the original style.
mrstyrofoam is offline   Reply With Quote
Old 09-13-2013, 06:33 PM   #2
Rewards Points: 14,312
If there's no sealer and just stain why are you sanding it?
Old 09-13-2013, 06:47 PM   #3
What do you suggest?
I don't know what the finish is, it looks dirty and a color I don't like. I just want to get to raw wood...so what is your advice?
Old 09-13-2013, 07:04 PM   #4
Jmayspaint's Avatar
Rewards Points: 536
I would think to just sand it. Media blasting might work, but sanding it smooth again would probably be more work than just sanding the stain off.
An orbital for the main areas, and a square vibrating sander or a mouse sander for the inside corners. It's no fun sanding overhead, but I can't see a better way...
Jmayspaint is offline   Reply With Quote
Old 09-13-2013, 07:11 PM   #5
Hope you know a good Chiropractor.
I'd try a drywall sanding machine to do the bulk of the sanding.
Home Depot rents them.
Covering unusual ceiling with wood Louie D Building & Construction 3 05-21-2013 05:44 PM
Insulating a Tongue and Groove Cathedral Ceiling tikitacky Insulation 9 02-04-2013 11:17 PM
Wood Ceiling panels discolored from Track Lighting DIY808 Carpentry 2 01-03-2012 06:11 AM
painting wood fiber ceiling tile sys72db Painting 4 09-25-2011 01:19 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
