Refinishing Exterior Door - Painting - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 01:12 PM   #1
Refinishing exterior door
I am refinishing my front door and need to know the best type of varnish or finish to use on it. The door faces the northwest and takes a beating from the elements.
Thanks for any advise.
shcorn is offline   Reply With Quote
Old 10-30-2008, 04:43 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
What is the door made of and what (if anything) is on it now?
The best stain/varnish type door finish I know of for wood doors is Sikkens Door and Window
It's a three coat system, and more of a urethane than varnish, but it's the best I've used (under some pretty harsh conditions out here)
You can use 3 coats clear, but the UV protection is minimal
I'd use at least one coat color (two coats clear)
But I'd say two coats color (one coat clear) is ideal
You can use 3 coats color for the best UV protection (like south facing doors in the Northern Hemisphere)
Spar varnishes have their own issues if not done every year, don't expand/contract enough in varied conditions (can crack and peal and discolor under those areas), and the slightest breach in finish takes lots of prep to re-do (and looks horrible until you do fix it)
That being said, it can be a great look if maintained, and your conditions may favor them more than others like mine
There are some other good "spar" urethanes (like Helmsman), but that Sikkens is hard to beat
slickshift is offline   Reply With Quote
Has Anyone Used Tubby Refinishing Kit JoanneHerr General DIY Discussions 10 06-25-2010 04:06 PM
Tub Refinishing kit Hawki39 Painting 3 10-12-2007 02:35 PM
Refinishing "golden oak" cabinets in kitchen - please help! Minnesota Gal Painting 6 08-12-2007 10:46 PM
Cost of Refinishing Hardwood Flooring ? Piney Flooring 2 03-27-2007 03:33 PM
Refinishing Tub and Tile ? Piney Painting 4 12-03-2006 09:02 AM
