Refinish Rusted Window Sill. Need Advice. - Painting - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 09:40 AM   #1
Refinish rusted window sill. Need advice.
I live in NYC in a building built in 1939. I decided to refinish 2 window sills and one radiator cover. I stripped the paint with a chemical stripper and quickly realized there was joint compound underneath the multiple paint layers.
Underneath that was rusted metal. Now this has turned into a bigger job than i thought. I need help figuring out what to do next and I have a basic plan, which is this:
use a wire brush or metal cup brush attached to a drill to get past all the joint compound and down to the metal. Sand the metal down. smooth out metal with Bondo filler. sand that down, use metal primer, then paint with an oil based rustoleum paint. I also bought a good mask in case there is lead paint in some of those old paint layers.
does this sound good? any suggestions?
you can respond to me directly at: backfist@gmail.com
thanks!! Neil from NY
kneel123 is offline   Reply With Quote
Tags
bondo , refinish , rust , sanding , window sills
Window Sill The Beam Carpentry 11 10-23-2011 03:55 PM
Window sill recess 4 a brick wall RedBear Building & Construction 0 07-17-2011 09:53 PM
Level sill buck or slanting out under window 4just1don Building & Construction 4 05-25-2011 01:01 PM
Need a little advice replacing basement window Bcoleman6 Building & Construction 1 06-08-2008 06:49 AM
Leaky window (sill) sable General DIY Discussions 5 10-08-2007 10:50 AM
