Recommended Primer And Paint - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-11-2010, 05:59 PM   #16
Originally Posted by alu View Post
Alright chrisn, thanks As you can tell I'm a little hard of hearing, but I got it now!
this is what you get for saying cost is no object. it is bad ass paint, just 2x the cost of other decent stuff
racebum is offline   Reply With Quote
The Following User Says Thank You to racebum For This Useful Post:
alu (07-11-2010)
Old 07-11-2010, 08:04 PM   #17
alu
OK, so for this small bathroom, I'm going with the top stuff.
What other decent stuff do you suggest for my large living room? I've had no problems with CIL paint, just needed 4 coats to make it look good enough to me. Anything between BM and the cheaper paints?
alu is offline   Reply With Quote
Old 07-11-2010, 08:20 PM   #18
OK, if money were no object,
Sherwin Williams or Benjamin Moore, or...?
I'd lean towards BM over SW. However I really like Pratt and Lambert Suprime primer and Accolade top coat for interiors.
Pratt is hard to find though.
I swear that a person could wear a black tuxedo and roll Pratt on a ceiling and there would not be a spec of splatter. It's such a pleasure to use. You can also have the paint store tint the primer to half the formula of the topcoat and then one topcoat will cover great .
hennyh is offline   Reply With Quote
Old 07-12-2010, 12:29 AM   #19
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Also , you should NEVER need more than 1 coat of primer( tinted) and 2 finish coats. You won't if you use good paint.Pittsburg paint would be my second choice,Duron and SW after that.
Old 07-12-2010, 11:03 AM   #20
Faron79's Avatar
Rewards Points: 260
Well...if $$ is no object....
If that's a scenario, get FPE paint!
I used their Eurolux Matte (actually more of an Eggshell sheen) in my lower-bath. I've never used paint this nice. I can load the wall up with moisture, let it sit, and wipe it down later...NO change in appearance at all.
Including shipping, it was $45/Qt.
Eurogallons are ~ $100.
I washed the walls with Dirtex powder first, primed with C2-One primer, then a single coat of the FPE.
Ya want the best?...this is it.
(I've had the good fortune to sample/test some of their other paints...WOW. I was sold completely on it when their Wine Red color COMPLETELY hid a white sample board, and I was pulling the coat as thin as I could with a crappy foam brush. I then torture-tested it by leaving some pop & water sit on it for a whole day. Every so often, I'd rub the water on it firmly. End of day...wiped it off...NO trace anything had been on it...not even a burnish mark!)
Faron
Faron79 is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 08:13 PM
