-   -   Recomendations for a Sprayer (http://www.diychatroom.com/f4/recomendations-sprayer-132548/)
hmu 02-04-2012 03:46 PM
Sorry to keep posting topics but I couldn't figure a way to change the title of my other one.
Anyway I've decided to buy a sprayer to paint the house and shed and outbuilding......Then I plan on probably selling it.....So I would like some advice. Airless or Air? Should I buy new big box store sprayer? A used one of better quality? I dont really want to spend more than about 400 500 max so not sure I could get a high quality new one or if it worth it for my needs. Thanks
joecaption 02-04-2012 04:00 PM
Airless only for bigger jobs.
I have a Graco XR 7 that's worked fo me for years. You can spray using 5 gal. buckets and it will spray almost any fluid.
housepaintingny 02-04-2012 04:53 PM
For your needs an airless sprayer that will spray at least.25gpm and has 3000psi would be sufficient. You will also want to be sure that the gun will accept at least a .015 tip for the maximum tip size, but one that goes up to .17 tip would be better, for your use you wouldn't need a larger tip than .017. Off course you can by bigger, but a small sprayer in that range is a good starting point for occasional use and within your budget. A piston pump sprayer will be better than a diaphragm pump and it sprays on the up and down stroke. The sprayers sold in box stores, even though they are brand name don't have as quality parts as ones sold else wear, such as SW.
joecaption 02-04-2012 05:00 PM
If you really plan on buying one and start painting as soon as you buy it then do not try and save money and buy a used one. One hose is about $75.00 a nozzle $15.00, rebuild kit for the pump $50.00. If it was not cleaned properly the last time it was used the cost can add up real quick.
Gymschu 02-04-2012 08:59 PM
Make sure your Homeowner's policy covers overspray onto the neighbors' car, house, dog, wife, kids, plants, etc.
hmu 02-05-2012 07:33 AM
SO a paint store is the place to go then? Or a better tool store like a northern tool etc??
Any chance a place like SW would give a discount if purchasing a sprayer and all paint from them? Or is that still a small purchase for them?
Any brand rec?
Thanks. You all are very helpful
hmu 02-05-2012 07:34 AM
Unless they overspray about 1200 ft I think Ill be ok:thumbsup:
jschaben 02-05-2012 08:13 AM
Hi - sounds like a job for an airless. Housepainting guy gave you a pretty good set of specs to look for. Look for Graco, Titan or SprayTech(Wagner), they all have pretty good units. Avoid the lower end Wagners though. The Wagner Paint Crew, as seen in WalMart, is just an exercise in frustration. I'd also avoid used as sold by an individual. Cleaning is so critical on these things buying used is just buying trouble. I said cleaning is critical, not difficult, but it does need to be thorough.
I'd recommend checking out the reconditioned market. You can get one meeting your requirements for around $200 here:
http://www.gleempaint.com/airspray.html
I've bought a couple of sprayers from these guys, a Spraytech 1420 and a Wagner Power Paint Pluis Max, and got good service and product a really decent price. I wouldn't count on reselling the thing though, at least not for a lot. There are a lot of guys like me that don't trust used paint equipment.
Good Luck:)
Gymschu 02-05-2012 08:55 AM
Hmu, if you just plan on a "one-time spray job" why not rent a unit? If you prep & mask well beforehand, you may only have to rent one for a day or two depending on the size of the job and your skill with the sprayer. Then, if you DO have any problems, you can contact the rental/paint store for advice, service, trouble-shooting, etc.
hmu 02-05-2012 09:31 AM
Thought about it but I have an 1100 sq ft house one side with 6 ft of basement exposure. Plus a shed (different color) and part of an outbuilding. I figure 24 hours between coats and some needs priming first so even if I can paint everything the same day thats 3 days. 70 a day is 210 280 if one more.....But maybe if its really that hard to sell them?
Brushjockey 02-05-2012 10:46 AM
Gleem is a good place to buy online- and good to compare/shop at
