Re Wallpapering : Do I Need To Remove Old Adhesive? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 07:33 AM   #16
Joe, that could have been a big OOOPPPS.
Old 11-28-2011, 06:23 PM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
I would bet good money that after 10 minutes soaking it would be wet toilet paper at best.
Old 11-28-2011, 09:33 PM   #18
Smokin Joe
jombres's Avatar
HAHAHA.
I guess I suffered from Premature Post-alation lol
SHould have checked what it said before posting....but anyways...
Okay 10 secs dip of the strip, and hand with no booking....you ever see that before? Did it work out okay?
jombres is offline   Reply With Quote
Old 11-29-2011, 03:46 AM   #19
chrisn's Avatar
Rewards Points: 394
Personally, I do not read the instructions, but in your'e case I would follow them and see how it works out. If it does not stick well, then book it for a couple minutes at most.
Old 12-04-2011, 07:49 AM   #20
Smokin Joe
jombres's Avatar
Hi Guys, I am sooo discouraged right now. Last night I started hanging my wallpaper, and followed the manufacturers instructions. I had two full sheets, plus a third cut and trimmed around the bow window. I came down this morning to the living room to find the seam on the first sheet pulling away. Im bringing photos of the paper plus the instructions (which state NOT to apply other paste to their product, as I think the store may suggest), to see what they say.
I attached photos and a scan of instructions here. The only thing I did different from the instructions, were to book the paper only to make it easier to carry from the work table to the wall. I did not let the paper sit for any length of time. Sheets 2 and 3 appear to be nicely adhered, but the first one...pulling away. Makes me consider whether I should continue or not...
To recap.....my old paper pulled off the walls easily.....then I,
1. I used hot water and vinegar rolled onto the old paste to loosen it
2. used scraper to remove loose paste,
3. rinsed/washed walls with hot vinegar water,
4. did second rinse with fresh hot water and different sponge/bucket and allowed to dry
5. coated walls with Zinser Gardz and allowed to dry.
What could I have messed up?
Joe.....conscientious but discouraged....
Re Wallpapering : Do I need to remove old adhesive?-paper-instructions.jpg   Re Wallpapering : Do I need to remove old adhesive?-img_0733.jpg   Re Wallpapering : Do I need to remove old adhesive?-img_0734.jpg
Old 12-04-2011, 08:03 AM   #21
chrisn's Avatar
Rewards Points: 394
Did you apply anything as a primer except the Gardz?
Did you hang the paper directly over the Gardz?
What kind of paper is it exactly?
Old 12-04-2011, 08:30 AM   #22
Smokin Joe
jombres's Avatar
No, I didnt apply anything yo the wall other than the Gardz.
The paper is paintable, textured paper, sold by Lowes, called Style Selections. It is a Venetian Plaster texture/pattern. Its made in the UK. Prior to purchasing it, I tried to find manufacturer instructions on a website, and the only sites that came up where it was mentioned were Lowes...so it must be their house brand.
The second sheet is from a second roll, and the third sheet (around the window) is from the same first roll as what came loose.
joe
Old 12-04-2011, 05:03 PM   #23
chrisn's Avatar
Rewards Points: 394
Well if I was doing it I would prime over the Gardz with a wall covering primer such as Romans ultra prime pro- 977 and most likely add some paste to the back also, but it is hard to say from here. Gardz will generally be all you need to hang over but the paper being from Lowes, who knows.
Old 12-04-2011, 05:17 PM   #24
Rubbin walls since'79
Brushjockey's Avatar
It is very hard to diagnose this way, but it does look like there wasn't enough adhesive, either didn't activate long enough or could add more.
When I do it i can feel how sticky it is, and if that feels enough for the paper.
If you're other sheets worked, think about why. Did you let them soak a bit longer- booked longer?
I also think the Gardz should be enough- I think the problem is with tack.
how are you pressing to wall? Using a plastic smoother, brush, your hand? Needs good even contact.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-04-2011, 08:44 PM   #25
Smokin Joe
jombres's Avatar
this morning before I headed out for the day, I lifted the edges and misted underneath the lifted paper with a mister spray bottle, and then pressed the paper down. I also noticed that the paper shrank I think a little, because the seams didnt match up like they did last night.
The girl at Lowes suggested seam sealer, or adding more paste, till I showed her the spot on the back of the instructions that says dont, lol.
I continued papering today and there was a time or too, that even with slow even pulling, I had some dry spots on the back of the paper, so using bright light and a glancing angle across the paper, misted those dry spots. That seemed to work for the most part the rest of the day, then at night, I saw a seam on a headed piece over the door way lifting up! I think what happened there, is maybe I butted the seams too tightly, and maybe the paper expanded a bit? I cut out a sliver of paper between the two pieces, dampened with the mister, and ran my fingers up and down the seam, which seemed to help. I'll see what it all looks like in the morning.
I hope this all works out, since the paper is a nice looking affect, and it does hide wall blemishes well and give it character. Im also thinking the paint may help seal the edges down a bit as well, but I know I cant rely on that, the paper has to be soundly on the wall.
Must say though, while the pieces were going up and I was brushing them, and the walls were getting covered, it was a bit therapuetic, and felt good to be getting some done.
Oh yeah, you asked how I spread it, I used a wall paper brush to smooth out and press the paper to the wall, and a 12" straight edge and knife to do the trimming. Very sparingly used a seam roller as I read they push more paste out of seams than help. SO I pretty much used only the brush, and ran it up and down over seams as well, and along door/window casings.
Old 12-04-2011, 09:21 PM   #26
BTW- this is your first. I was trained and it took a couple of years and really never stopped to get good at it.
I would also get a plastic smoother and use that from top to bottom. on heavier stock a brush isn't enough. In fact, 99% of the time I smooth with a plastic smoother, just use different angles, pressure depending on material.
Another advantage to rolling the water/paste on with a table is you can see it gets on everything uniformly. You can see this is important. Booking even your way will help.
Give it a few mins. 3-5.
Old 12-04-2011, 09:22 PM   #27
Use a 6" for trimming- you wont ride over humps and things- slide it along as you trim.
Old 12-20-2011, 04:19 PM   #28
Smokin Joe
jombres's Avatar
Hi Everybody, just wanted to let you all know, my papering project came out pretty darn nice! The problem I had with the one piece separating from the wall, I think was due to not noticing that there was a dry spot (or not-as-wet) from perhaps a poor pull out of the water tray. Subsequent whole sheets I applied, I kept a sprayer bottle handy and added a few mists here and there if needed, and I also booked the paper for a little while (minute or so) even though instructions did not call for it, to help even moisture out from booked surface to surface.
I actually enjoyed the process of hanging the wallpaper and seeing it transform my living room and hallway.
Then I painted the paper and walls and it really came alive. Changed my outlets and switches, the hallway ceiling light, and then out came all the Christmas decorations. Over my vacation I will hang the sheets up the stairwell, and upstairs hallway, but overall, I am quite pleased with how this project turned out so far.
I wanted to thank you all publicly for your comments, suggestions, and experiences!
I wish you and your families all a joyous Merry Christmas, Hanukah, and New Years! Thank You all.
Joe
Old 12-20-2011, 04:26 PM   #29
I love happy endings!
Old 12-20-2011, 08:45 PM   #30
Good job guys!
Removing tile adhesive from concrete floor CCaballero Flooring 0 04-24-2011 04:14 AM
Trying to remove flush mount finish nails pms1228 General DIY Discussions 18 03-15-2011 09:42 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Hardwood has a subfloor on top that I would like to remove capslock Flooring 3 04-01-2008 10:27 AM
Getting adhesive off walls dm62 Remodeling 5 04-14-2005 12:50 PM
