01-18-2013, 02:05 PM
#1
Re-Stain Deck - Best Prep and What to use?
I have a large deck that was stained by the previous owner. The previous stain was Behr Solid Stain Acrylic based. The finish has probably been on for around 5 years and it is peeling, fading and very dirty. I am leaning towards an oil based Cabot stain to refinish. I am also planning on powerwashing, scrubbing dirty areas and sanding off any chipping areas of the deck before I apply the new stain. Does anyone have any results with this scenario? Does anyone recommend a different approach? (I am trying to avoid priming and based on what I have read the oil-based new stain should soak in but because of the quality issues with Behr I am unsure if this approach will last.) The deck is on the south side of the house with full sun 100% of the time.
01-18-2013, 05:54 PM
#2
paper hanger and painter
Don't use it.
Where are you?
01-18-2013, 05:55 PM
#3
I have never understood why someone would build a deck that is in sun.Maybe they were sunbathers, I don't know.I think your approach would work fine with a solid color stain.
Charlie Daniels painting and repair
01-19-2013, 12:33 AM
#4
Yes oil stain is the way to go for any walking sufaces. I had the exact same situation when my GF bought her house. Get all the old stain off first and some 36 grit sandpaper and a palm sander made really quick work of it for me.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
01-19-2013, 01:12 AM
#5
Deck Staining Pro
Are you talking about using an oil solid? You may have trouble with that over the existing Behr. How much of the old stain is gone? If you can strip it all off I would suggest using an oil semi transparent.
Charlie Soden
Apex DeckSavers
"Bringing New life to Old Wood"
01-19-2013, 01:17 AM
#6
Deck Staining Pro
Most of the projects we do with peeling solid we prime first and then top coat. At least that way you have better shot of avoiding peeling when going over a questionable previous stain that may continue to peel and pull the new stain off with it.
Charlie Soden
Apex DeckSavers
01-19-2013, 08:37 AM
#7
http://www.deckstainhelp.com/
This is a great site? I used the restore-a-deck stripper and it worked great
01-19-2013, 11:16 AM
#8
I do not recommend priming underneath a stain, atleast not an oil stain that by design will wear away over time. Now if you prime underneath an oil stain when it starts to wear away you will see the primer underneath, not to mention you are inhibiting the stain's abaility to penetrate the wood properly.
01-19-2013, 01:47 PM
#9
Deck Staining Pro
Im talking about solid stains here where penetration is already ruined by having an existing solid stain on top. Thats why I ask him whether he is talking about an oil based solid stain or what we traditionally consider oil as a semi transparent. We have had problems only doing two coats of an oil solid over a film forming latex already on the deck.
Charlie Soden
Apex DeckSavers
01-19-2013, 06:47 PM
#10
Painting Company, NY
When dealing with failed stain you want to strip and remove all of the old stain. A sodium hydroxide based deck stripper will remove the stain. Use a pressure washer with 500-800psi. You don't need, nor do you want high pressure when dealing with wood restoration. After using a sodium hydroxide stripper you will need to neutralize with an acid, such as citralic. You will also need a nylon brush to agitate. Be careful using the stripper if this is the route you choose. Follow instructions. We strip all stain off of decks, siding and log homes prior to staining if the stain has not been maintained and is failing. Once you stain your deck follow up once or twice a year with a cleaning and probably every other year with a maintenance coat. You will also want to be sure that the deck is dry prior to applying stain.
The Following User Says Thank You to housepaintingny For This Useful Post:
01-20-2013, 02:34 PM
#11
You are going to have to strip off all the old Behr, look for RipIt or HD80 followed by washing with an acid to neutralize. Strip until all the Behr is gone. What color was the Behr? Red is almost impossible to fully remove.
I have had customers with odd color decks of Behr, bright blue, silver, and had to do multiple strips of the acylic finish to remove so do not be surprised that a lot of work is involved. Better yet hire a pro to do it correctly as strippers are VERY DANGEROUS to work with.
Now about the finish. Cabots I would not recommend no matter what Consumer Reports tells you. Look at what the pros use.
01-22-2013, 09:50 AM
#12
Get yourself some 36 or 40 grit sandpaper and palm sander and you will be shocked how quick that old stain will come up. It will also strip the top layer of dried out wood and leave you a great surface for painting. Unless you are going to use the full strength stuff the pro's use that DOES eat holes in your skin the stippers are weak.
I spent a whole day using the weaker DIY strippers on my girlfriends large deck a couple years ago and got maybe 25% of the remaining stain off. The next day I used 36 grit and had the whole deck done in less that 4 hours ready to stain.
01-25-2013, 11:59 AM
#13
Update: There are quite a few questions in the replies and will do my best to handle them.
I am outside of Chicago so the deck gets all the weather elements. Also, the deck is big, 36 ft x 12 ft with some stairs and railings all around it. Because of the size, I am really not looking to strip the entire deck. The previous color is suppose to be "Cedar" but it just plain orange to me which is a big reason I want to get rid of it. The railings, except for the top, are actually doing fine so it seems I could stain/paint right over the top. The real wear and tear comes in on the deck surface. Since it is supposedly a "stain" rather than a "paint" it has worn all the way down to the wood color (rather than pealed) but definitely not enough that I could use anything semi-transparent over the top.
I also wanted to avoid priming because it is going to take me long enough just to get one coat on. Now, I want to get this done right so that it will last so if I go to all the trouble of stripping the deck then I will probably not put a new solid stain over the top. (The big problem is that someone used Solid stain in the first place.)
Which option should I use? (There seems to be pros and cons including time and effort but ultimately I want the best solution)
Option 1: Powerwash, Sand where needed, re-stain with Oil based solid stain?
Option 2: Strip the deck and then re-stain with Oil based stain (semi transparent or solid)?
Option 3: Prime the deck and the re-stain with Oil based solid stain?
Also, should I use an Arcylic based stain? Or better yet, what do the "Pros" use (as someone suggested)?
01-25-2013, 12:42 PM
#14
This is what I do for a living. First I would strip the deck followed by neutralizing to get the wood ph back to normal. Then let it dry to 12% moisture content. Once it is dry I would seal all surfaces with either Ready Seal or Armstrong Clark sealer. Dealing with strippers is dangerous so I charge accordingly because you not only have liquid being used but it is sprayed on so you are breathing it in. Use a respirator, rubber gloves, boots and rain suit. Another reason it costs to strip, it is not fun to be dressed for a long time while stripping a deck. I would never guarantee a job unless I stripped any old sealer on a deck. If the customer does not want it stripped I decline the job. DO NOT RETURN TO BEHR.
01-25-2013, 09:53 PM
#15
I agree with the Captin. The proper way to re finish a deck that has failed stain is to suit up in protective gear and use a sodium hydroxide based stripper I.e. HD-80. Then neutralize and balance the ph by using an acid I.e Citralic. Use a scrub brush, low pressure, read the directions and let the chemicals do the work. Both Ready Seal is a great stain. A product like hd80 is the most cost effective stripper per square foot and will remove behr stain.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
