Re-Painting 55 Gallon Drum - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2012, 06:22 AM   #1
Rewards Points: 284
Any suggestions for re-painting a 55 gallon drum?
How should it be prepped?
What is the best type of paint (enamel, polyurathane, etc) to use?
Thanks.
Earnie is offline   Reply With Quote
Old 07-20-2012, 06:42 AM   #2
the Musigician
DangerMouse's Avatar
Metal or plastic?
DM
Old 07-20-2012, 08:46 AM   #3
Rewards Points: 284
It's a standard metal 55 gallon drum with a bit of rust also. I can sand that off.
Old 07-20-2012, 08:52 AM   #4
TWX
Rewards Points: 35
What kind of use will the drum see? There are many different ways of painting steel, and usually they're application-specific. I wouldn't suggest painting a 55 gallon drum that's to be used as a planter the same as I'd suggest for one being used to hold scrap lumber or for one being used to hold reclaimed rainwater...
TWX is offline   Reply With Quote
Old 07-20-2012, 08:52 AM   #5
the Musigician
What are the plans for the drum after painting it? i.e. rain barrel?
DM
Old 07-20-2012, 09:14 AM   #6
Rewards Points: 284
The drum originally contained bulk engine oil. At some point it was used to store diesel fuel. That is my plan also.
The drum could use a good coat of paint for corrosion protection. It will get some sanding. I just need to know what to use as a paint.
Old 07-20-2012, 01:05 PM   #7
ltd
Rewards Points: 536
rustoleum professional oil base paint qt, ,rustoleum primer to spot prime qt, or rattle can .and cheep but not to cheep throw away brush. get it at the big box
ltd is offline   Reply With Quote
Old 07-20-2012, 03:56 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 628
couple cans of this will do it
after cleaning and rust removal
sorry that is the primer but the finish paint is right there with it @ any big box
chrisn is online now   Reply With Quote
Old 07-21-2012, 06:28 AM   #9
Rewards Points: 284
I thought about using spray cans but wasn't sure they would hold up.
Thanks.
Kitchen painting questions after odd Benjamin Moore visit sixxmum Painting 14 07-18-2012 10:12 AM
rain barrel of 55 gallon drum ladylusi Building & Construction 5 07-07-2012 07:10 AM
Can you cut a 55 gallon drum with a jigsaw? tibberous Building & Construction 9 11-07-2011 06:48 AM
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
