Range Vent. - Painting - DIY Chatroom Home Improvement Forum
Old 04-12-2009, 09:16 PM   #1
Range Vent.
I spray painted my range vent with Rustoleum lacquer. I have some over spray and was wondering if one can wet sand this paint.
Graybeard is offline   Reply With Quote
Old 04-13-2009, 11:33 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
What did you get overspray on?
Old 04-13-2009, 11:59 AM   #3
Rewards Points: 506
What surface did you get the overspray on?
sirwired is offline   Reply With Quote
Old 04-13-2009, 05:34 PM   #4
Maybe over spray was the wrong term...It's supposed to be a high gloss finish and it's rough, so I was wondering if I could wet sand it smooth and make it glossy like a car.
Old 04-13-2009, 07:53 PM   #5
Rewards Points: 506
Oh, in that case, yes, carefully wet-sanding the paint should enhance the gloss. If the paint appears to be too soft for this, try automotive enamel.
SirWired
Old 04-13-2009, 08:39 PM   #6
Rewards Points: 150
you're probably thinking of orange peel finish
http://en.wikipedia.org/wiki/Orange_peel_(paint)
johnnyboy is offline   Reply With Quote
Old 04-13-2009, 09:26 PM   #7
I called it over spray because it is like dust on the finish not like orange peel. I wa thinking wet sanding or a polishing compound would smooth it out. I'm going to let the paint cure for a few days and try wet sanding.
Old 04-14-2009, 11:58 PM   #8
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Ah - I think I know exactly what you are talking about. Either you got a bad can, it wasn't mixed well enough, or you are spraying at the wrong temperature. I try to avoid Rustoleum as much as possible because of its tempermentality. There are less-expensive brands that are easier to use than Rustoleum, especially their brush-on enamel - terrible. But I have seen a few cars painted and sanded to a really nice finish with Rustoleum...
I found this miracle paint called Rust Stop at Ace Hardware - one of their brands that's actually worth using. THIS will give you close to show car finish with one coat.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
range hood vent vinman Roofing/Siding 6 05-07-2012 02:23 PM
Range hood vent going into attic? gante Building & Construction 7 03-25-2009 05:45 PM
Installing range hood - wall vent DIYGST HVAC 3 01-04-2009 08:45 AM
Wall vent for over the range microwave JoeClark Building & Construction 3 11-29-2008 01:11 PM
Range Hood Vent powrus Appliances 2 11-08-2007 03:07 AM
