Rain Between Sanding And Washing? - Painting - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 01:19 PM   #1
Rain between sanding and washing?
Hi; I rented a sander and did my (PT) deck. Unfortunately I ran out of time to get the stain in before we had a day of heavy rain. I'm just wondering/hoping I didn't waste my efforts sanding? Will a day of rain, plus a day to dry out, have a big negative effect on the project? I've already returned the sander, just wondering if it is worth it to (a) re-rent it, or (b) get down with my hand sander to do some/all spots with a light sand.
dcamell is offline   Reply With Quote
Old 06-03-2013, 02:45 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
I wouldn't think a few days would make that much difference. Make sure the deck is dry, its hard to tell just by looking/guessing. A simple moisture meter will tell you for sure. You can get them at a lot of paint stores for around $30.
Example, it rained here last night and was cloudy this morning. These logs are under a porch and wouldn't get direct rain, you might assume they are dry. Not really though. 18% is the max for staining, but I like it below 12%
It is best to sand ( and dust/blow off) right before staining IMO . If you have the time and want to be extra cautious, even a light sand will help. I thin its more about sun damage than getting wet/drying, even a few days in the sun will affect the surface.
Jmayspaint is online now   Reply With Quote
Old 06-03-2013, 02:56 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
Think I sounded a little wishy-washy there.
Better answer is; Yes, for best results re sand, and make sure its dry.
But it probably won't be a disaster if you don't re sand as long as its dry.
Old 06-03-2013, 02:59 PM   #4
Ha! No, not wishy washy, just detailed! Thanks; that's a neat little device. I will look for one.
Old 06-04-2013, 08:03 AM   #5
Rewards Points: 5,974
I agree on letting it dry the biggest cause of paint failure is moisture. I don't think a day to dry is enough.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
cdaniels (06-04-2013), clambake6 (06-04-2013)
Old 06-04-2013, 12:18 PM   #6
cdaniels's Avatar
Every exterior stain I know calls for 2-3 days drying time after washing or rain.Follow the label directions and you will be fine.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Deck Staining GanJa Painting 20 02-11-2014 02:47 AM
Deck staining: percarbonate and power washing? WorBry Painting 15 09-01-2012 12:14 AM
Splinters/ Sanding a wood deck adam3477 Carpentry 6 06-20-2011 04:27 PM
is pressure washing enough then prime and paint? NWFixer Painting 1 06-09-2011 05:31 PM
Washing surfaces before BIN coat jsheridan Painting 3 03-19-2011 11:21 AM
