Quick, Dirty Way To Fix This? - Painting - DIY Chatroom Home Improvement Forum
Old 05-11-2008, 02:31 PM   #1
Question
Quick, dirty way to fix this?
I recently painted a wall with two coats. The first coat had 24 hours to dry. I then applied a second coat, and after 3 hours drying time, here is what it looks like:
As you can see, it's quite patchy in that one section. This only occurred after the second coat. It wasn't like this before. I'm fairly certain the paint was just spread too thin on those sections.
How can I fix the patchiness? Can I get away with painting on a third layer? I am afraid that three layers will be noticeably different from the other walls (the other walls only have one layer and look just fine, so I'm leaving them be). Will that happen with a third layer, or does it look the same?
Paint is Beauti-Tone with Velvet finish (latex paint). I should also add that the second coat has now had 24 hours to dry (the photo was taken last night).
pro_DIYer is offline   Reply With Quote
Old 05-11-2008, 07:03 PM   #2
Rewards Points: 506
Does it still look like that? Some paints will look much better as they cure. Curing (as opposed to drying) can take several days. The time on the can is merely the time until you can top-coat again without destroying your existing paint job.
If it doesn't clear up after a day or two, I would go with top-line paint from a paint store as opposed to that BigBox paint you are using now.
What kind of temperature and humidity is it where you are?
SirWired
sirwired is offline   Reply With Quote
Old 05-11-2008, 07:28 PM   #3
I went ahead and painted over it again. It fixed that particular patch, but now there is patchiness elsewhere.
The idea was to fix this with no money. I'm a student, in an apartment, and wanted to spruce it up a bit. I wasn't really wanting to spend anymore on paint or anything. I guess I will just have to live with it.
Old 05-12-2008, 07:07 PM   #4
Just for record's sake, here's how it looks like now:
As you can see, fit went rom bad to worse. Upon closer inspection, it just seems like it got rolled on too thin on those 2 vertical strips for some reason (close up, it looks grainy and rough). The colour is actually the same, it's just the sheen that is different (i.e. it's much less shiny).
Seeing as I can't stand it, I'm going to get a 1 L can and go over the whole wall one last time. I will have to do this tomorrow though, making it 48 hours since the last time I painted. Is it bad to wait that long to paint another layer?
Old 05-13-2008, 04:44 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 472
Looks to me like there was wallpaper on the walls at one time??
Old 05-13-2008, 05:47 AM   #6
Rewards Points: 530
Are you using the same roller each time? Is it clean? Paint sealed tightly between coats? May be time for a little skimming, priming then repaint with good clean roller sleeve with the same nap as previously used. Oh, and be sure the roller stays loaded with paint completely around the sleeve. No dry rolling. The first pic looks like the roller wasn't completely rolled into the tray and had dry areas on it making skipped areas on the wall or maybe you were trying to squeeze too much paint out of the roller before rewetting it.
Old 05-13-2008, 01:22 PM   #7
Nope, that's just me rolling on the paint too thin on some parts.
Old 05-13-2008, 09:49 PM   #8
Pro Painter
There's something going on with that area of the wall. You said it's rough, is that because of the paint? Is that an area where drywall joint compound was used and not primed? Is it just a rough area that needs to be sanded?
Does the wall dip in those two spots and your roller isn't filling it in?
Are you running out of paint and added water?
Can't really tell from the picture alone, but maybe you can figure it out using the above questions.
joewho is offline   Reply With Quote
Old 05-15-2008, 07:47 AM   #9
Rewards Points: 530
Not sure what I meant by that, unless I was thinkiing between old paint and new paint if sealing or priming was necessary. Heheh, maybe sanded lightly would be more appropriate.
Has anyone used the Watts Quick Connect Fittings? luweee Plumbing 8 02-28-2011 08:02 PM
Quick connect sink? rick32 Plumbing 2 12-13-2007 01:07 PM
Behr Quick Fix Deck Stain Remover mahjohn General DIY Discussions 1 12-04-2007 10:39 AM
