Questions On Molding/window Frames - Painting - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 12:14 PM   #1
Rewards Points: 14
Questions on molding/window frames
Hello,
I am in SoCal and I recently got an old house. Unfortunately it is covered inside and out with oil based paint... Recently I asked a question regarding oil based paint and it was recommended that I use zinsser. I ended up getting the oil based cover stain blocker and it seemed to go on fine outside of its a pain to cut with due to brush strokes etc.
My questions are what's the best route to apply this primer to the door way frames, window frames and shiny kitchen cupboards should I
1. sand them really well or
2.should I apply a paint remover so that I can scrap/wipe it off
3. Clean them well and lightly sand them with a high grit sand paper and Just paint the oil based primer and then paint over it...
4. Do the same as 3 but instead of the cover stain just use a latex paint such as zinsser's bin...
I have attached pictures of the frame and the kitchen cabinets.
Thanks! Another helpful tidbits would be great too....
Questions on molding/window frames-image-1974054337.jpg   Questions on molding/window frames-image-3192770690.jpg
socrates is offline   Reply With Quote
Old 09-02-2012, 12:53 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
well, lets see- #3 with some modifications..
Clean ,( soilex, dirtex, Krud Kutter or tsp/ tsp substitute- real labels and follow) sand with not heavy but med- med fine ( 150-220 grit). The idea is to break up the gloss- not remove the paint. Then the primer will have the ability to get a mechanical bond besides the chemical one that it has.
Cover stain could use a _small_ shot of mineral spirits in it to get it to handle better.
BIN is a shellac based primer- and while it will do the job well, is even harder to handle than the cover stain.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-02-2012, 07:01 PM   #3
Rewards Points: 14
Thanks and as for the side of the house is that also a decent exterior primer? I want something that'll last awhile incase I have to leave it in a few months before I paint... I have to replace about 25% of the siding around the house...
Old 09-02-2012, 07:09 PM   #4
Rewards Points: 13,960
You should not leave primer exposed.
I like to sand all of it, prime and paint all sides then paint it one coat before even going up. That way all sides are sealed, less chance of it cupping.
Then all you have to do is the touch up painting to do.
Old 09-02-2012, 07:38 PM   #5
Rewards Points: 14
It's ok to leave primer exposed on interior walls right...?
Old 09-02-2012, 07:44 PM   #6
Too Short? Cut it Again!
Depending on what type of siding you have you might consider a quality solid acrylic stain like SW Woodscapes. You can mix it to any color. Apply to new or painted siding.
Old 09-02-2012, 10:31 PM   #7
ltd
Rewards Points: 536
just a little tip .when using oil cover stain i prefer to use a nylon polyester brush vs a china bristle brush.also as mentioned a splash of thinner in your cutting bucket
ltd is offline   Reply With Quote
Old 09-03-2012, 03:39 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 472
not for too long
Old 09-03-2012, 01:40 PM   #9
Bombastic Idiot
notmrjohn's Avatar
Best not to leave bare primer or 1st coat un=coated in kitchen any longer than neccessary, amazing how much oil and grease is in air and you just spent time cleaning it from cabinets. Hey, really like that partical board window treatment.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-03-2012, 06:13 PM   #10
Rewards Points: 14
thanks, so far I've just primed the family room I didn't even mess with the kitchen because all the walls and ceiling needs to be floated. Ya the particle board window treatment has been my favorite part.... Long story short swat blew out all the windows with bean bags tear gas and everything else and made some pretty good marks in the walls too... I am finally almost done replacing the windows it's been a pretty fun ordeal... Not only was the house in pretty sad shape to begin with but swat coming there three times to blow out windows knock down doors etc didn't help the situation...... Once it's done though It'll be great... until then all I can do is keep chipping away at the projects...
Old 09-03-2012, 11:05 PM   #11
Bombastic Idiot
notmrjohn's Avatar
...swat blew out all the windows with bean bags tear gas... swat coming there three time...s
Ask um to pretty please stop doing that, specially after you put in all that work.
Old 09-03-2012, 11:35 PM   #12
Rewards Points: 14
hahaha ya, luckily unlike the previous owner I don't plan to cause problems... It's all uphill from here! haha
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
New window frames? PCMLR Carpentry 2 10-08-2010 11:23 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-24-2010 11:53 PM
A few roof questions before I begin... chrisexv6 Roofing/Siding 6 05-02-2010 06:16 AM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
