Question On Prepping Exterior - Painting - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 11:01 AM   #1
question on prepping exterior
I am getting ready to prep a area to paint it, I can tell that when I blast it with a pressure washer or scrape it I am going to have areas where there is bare wood, does that mean I should be primming the whole area I am painting? I went to Sherwin williams and got oil based primmer and latex paint for a area I have already done but on that area I had the wood just about bare.
I have seen the term (spot primming) is that something I would want to do or is that kind of cutting cornners, I am planning on being in this house for many years to come so I dont want to do any thing that is going to cut life or quality off my paint job.
Thanks, Doug
schermd is offline   Reply With Quote
Old 05-08-2011, 11:04 AM   #2
Learning by Doing
Leah Frances's Avatar
All areas to be painted should be primed.
Power washing is a risky way to prep.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-08-2011, 11:12 AM   #3
Thanks for the answer on the primming, so, I should just scrape and sand?
Old 05-08-2011, 11:19 AM   #4
Home Remodeler
Rewards Points: 164
I would power wash, just enough to remove the loose paint and dirt.
mikey48 is offline   Reply With Quote
Old 05-08-2011, 01:30 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
and then scrape, sand , prime and paint
Old 05-08-2011, 01:32 PM   #6
Learning by Doing
For the sake of clarifying my statement. If you are getting down to bare wood with your pressure washer take great care not to gouge your wood.
Also, make sure your bare wood is entirely dry before you start trying to prime.
Good luck.
Old 05-08-2011, 06:07 PM   #7
chrisn's Avatar
Rewards Points: 128
Good luck.
Old 05-08-2011, 09:14 PM   #8
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Everyone has already summed it up, but don't forget to caulk after priming where any trim meets siding, sofit, fascia, etc as needed.
housepaintingny is offline   Reply With Quote
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Exterior Light gregt848 Electrical 2 03-13-2010 02:50 AM
Exterior wall framing question Pmatyj01 Carpentry 5 10-04-2009 02:09 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Arching an exterior wall in Kitchen Question Tristar Carpentry 1 03-26-2008 06:31 AM
