Question On Gardz - Painting - DIY Chatroom Home Improvement Forum
Closed Thread
Old 10-28-2013, 09:47 AM   #1
Rewards Points: 45
Question on Gardz
Just finished applying Gardz on all the walls of my family room after stripping all the wallpaper and patching the walls - which were a mess under the paper.
Do I need any other primer over the Gardz? I'm worried that I won't get a consistent sheen to the paint given all the spot repairs on the walls. Will any of the repairs show through the Gardz or am I all set for my finish coat?
* Photo is prior to applying the Gardz...
Question on Gardz-img_20131018_074248_099.jpg   Question on Gardz-img_20131018_074209_413.jpg
dschribs is offline
Old 10-28-2013, 10:45 AM   #2
The manufacturer recommends you do. its a sealer.
vividpainting is offline
Old 10-28-2013, 11:30 AM   #3
Rewards Points: 5,974
Just to be sure I went and read my can of Gardz it says after Gardz apply 1st coat of paint.
ToolSeeker is offline
The Following User Says Thank You to ToolSeeker For This Useful Post:
vividpainting (10-28-2013)
Old 10-28-2013, 11:46 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
As long as all the patches have a coat of Gardz on them then you will be fine with 2 finish coats and paint sticks to Gardz with no problems.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Matthewt1970 is offline
Old 10-28-2013, 01:10 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Your now ready for 2 coats of SW superpaint.
747 is offline
The Following User Says Thank You to 747 For This Useful Post:
Gymschu (10-28-2013)
Old 10-28-2013, 01:23 PM   #6
Rewards Points: 45
Thanks all.
I use B Moore Regal Select.
dschribs is offline
Old 10-28-2013, 01:33 PM   #7
747
registered
747's Avatar
Rewards Points: 534
Originally Posted by dschribs View Post
Thanks all.
Thats ok to.
747 is offline
Old 10-28-2013, 01:34 PM   #8
Thanks, i wasnt aware of that.
The Following User Says Thank You to vividpainting For This Useful Post:
ToolSeeker (10-28-2013)
Old 10-28-2013, 03:46 PM   #9
Rubbin walls since'79
Brushjockey's Avatar
Gardz is a great primer. But because it's clear, it obviously wont help with coverage, but it does a great job in evening out the porosity of the patches, and kind of "resetting" the whole surface.
Paint ready, expect 2 coats.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline
Old 11-04-2013, 04:07 PM   #10
Rewards Points: 4,796
Originally Posted by Brushjockey View Post
Gardz is a great primer. But because it's clear, it obviously wont help with coverage...
Since you brought it up, technically it might help with coverage. Here's just one example. You're repainting the walls the same color as before, but you need a primer for whatever reason. In this case you're better off with a clear primer than a white primer, or even a beige tinted primer. (Assuming the clear primer does everything else you want it to do.)
jeffnc is offline
Old 11-05-2013, 05:07 AM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 464
nit picking
chrisn is offline
The Following User Says Thank You to chrisn For This Useful Post:
oh'mike (11-05-2013)
Old 11-05-2013, 08:39 AM   #12
You need to lighten up, Francis. I'm not "nit picking" someone else's answer, I'm pointing out what can be an advantage to using a clear primer.
From Kilz Klear's ad page: "Particularly effective for ‘same color painting’, KILZ KLEAR will bond and seal porous and chalky surfaces with little change to current color."
http://www.kilz.com/primer/v/index.j...00216310acRCRD
jeffnc is offline
Old 11-05-2013, 02:13 PM   #13
chrisn's Avatar
Rewards Points: 464
Gardz and Kilz are hardly the same thing
chrisn is offline
Old 11-05-2013, 02:47 PM   #14
Jmayspaint's Avatar
Rewards Points: 534
Nitpicking
Jmayspaint is online now
Old 11-05-2013, 02:48 PM   #15
So what? That's not the point. At all. Use your noggin man. We're talking about clear primers, where sometimes clarity is actually desirable from a color standpoint.
jeffnc is offline
Closed Thread
Gardz Question dschribs Painting 6 07-30-2013 11:25 PM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
Brittle popcorn, water stains: Gardz and/or BIN jfklein13 Painting 7 06-01-2012 09:17 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
