Question About Using Kilz Original - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 06:38 PM   #16
Sprayboy-services.com
+1 on BIN. Unless you are spraying it on I wouldn't worry about the house blowing up but do ventilate well for your health.
Sprayboy is offline   Reply With Quote
The Following User Says Thank You to Sprayboy For This Useful Post:
ultrasilc (12-25-2010)
Old 12-24-2010, 02:59 PM   #17
hello, first time on forum.. Painting Bathroom. Oil paint on walls. Purchase Kilz orginal oil base primer (recommended by home depot). Have gas furnace and water heater in basement. gas stove. SEASON WINTER. QUESTION: Don't know much about kilz, but was told to purchase this. I am confused now> I was told to purchase this product because oil base paint was on my walls color is light green.... and white ....I want to repaint (no oil base).. neutral color.....
my home is pretty big 1200 on first level and 700 in basement..... do I still need to turn off gas in order to use kilz? Can I paint walls and open window (cold) for ventilation..... DON'T KNOW WHAT TO DO... BUT I NEED TO DO SOMETHING...... REDECORATING....WANT TO PAINT BEFORE I PUT IN NEW FIXTURES.....
NEED YOUR ADVICE AS TO WHAT TO DO........... THANK YOU
ultrasilc is offline   Reply With Quote
Old 12-24-2010, 03:44 PM   #18
No, oil-based paint is not that flammable. Laquer is a different story.
Old 12-25-2010, 06:47 AM   #19
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
You will srill need fresh moving so you don't pass out from the fumes.
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
Old 12-25-2010, 07:28 AM   #20
Will the drying time be longer since it is winter?
Old 12-25-2010, 10:42 AM   #21
Is it winter in your house???? Close the windows and doors then. Actually, winter indoor conditions tend to be drier than summer.
Tags
kilz , primer
Cleaning paint brush of Kilz Original torsade Painting 2 10-31-2010 04:36 PM
Patched Drywall is thinner than Original. I need Suggestions. thehip Drywall & Plaster 9 08-02-2010 11:34 AM
Going back to original flooring in Baltimore House kilroyrock Flooring 5 03-29-2010 10:19 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
