Question About Painting Plastics - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 07:53 PM   #1
Question about Painting Plastics
Hi. I'm trying to do a custom job on a paintball marker. Some of the parts are plastic. Of the plastic parts some are hard plastic, and not too oily, and others are softer and more oily. I've gotten some Krylon Fusion to do the job, in a camo pattern and I'll use that as my base. I've also got some Rustoleum flat camo paint so that I can do a 6 color patten.
I actually have two questions. First I assume I'm good using the fusion paint on metal along with the Rustoleum.
My real question is that if I use the Fusion as my base on the plastic, can I use the Rustoleum on the plastic and it adhere to my base Fusion coat?
Thanks.
BuckeyeGuy is offline   Reply With Quote
Old 02-24-2009, 06:45 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I've used Fusion before as a prime coat without issue. Seems to work fine. As for Fusion on metal, I don't recommend it. Almost every time I've sprayed metal with Fusion it flakes off in short order.
poppameth is offline   Reply With Quote
Old 02-24-2009, 10:48 AM   #3
Thanks for the response. What if I spray with a non fusion Krylon primer first. Do you think I'll be ok then? I'm trying to keep a consistant color usage between by metal and plastic parts.
Old 02-25-2009, 06:55 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yep that'll work. I painted a computer case a while back. All of it except the removable side panel was plastic. Fusion bonded fine. I had to sand the metal panel and prime it with Krylon's Ruddy Brown primer. The Fusion bonded fine to the primer.
Old 02-25-2009, 08:59 AM   #5
I always wipe any plastic or piece with a sheen with wilbond. It makes your surface bondable.
waynech is offline   Reply With Quote
Exterior Painting Question jmm8877 Painting 19 09-18-2008 08:27 AM
Painting a door red outside, white on the inside - quick question joeyboy Painting 6 08-26-2007 04:37 PM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 05:12 PM
