Question About Colored Spackle/Textured Wall - Painting - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 10:40 AM   #1
Question about colored spackle/Textured wall
Hi everyone,
I have a textured white wall that I want to smooth it and re-paint it with a green color. I bought a can of wall spackle and when I reached home I found that it's a grey (colored) spackle. The question is, is it possible to use the grey spackle and then to use white prime over the spackle and then to paint with a green color?
Thanks in advance
latvian is offline   Reply With Quote
Old 06-20-2010, 06:11 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Originally Posted by latvian View Post
Hi everyone,
Thanks in advance
It should not be a problem, I don't know what kind you bought, but some joint compounds and spackle do have a grayish, off white color, as long as you prime the repair and apply two top coats of paint you will be ok.
housepaintingny is offline   Reply With Quote
Old 06-20-2010, 07:19 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Yup...just fine as you presented it
slickshift is offline   Reply With Quote
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 10:37 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 10:02 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
