Question About Beadboard - Painting - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 03:45 PM   #1
Question about Beadboard
Hi All - I'd like to get some input on an idea I have and ask if anyone's ever done it:
I have a nice kitchen with a 3-wall nook section for a table. The previous owners installed beadboard on these three walls from floor to ceiling. The only other beadboard in the kitchen is on the outside of the island facing the nook.
To save time and money, I thought that it might be a neat idea to add a chair rail to the beadboard walls and leave the bottom white and paint the top the wall color of the rest of the room.
Would this look odd? Has anyone ever done this?
Thanks for the input!
TechMistress is offline   Reply With Quote
Old 02-11-2011, 05:34 PM   #2
Rewards Points: 526
I have never seen this done, but my gut is telling me it wouldn't look good. Might be better to paint all of the beadboard a color that contrasts with the other walls, rather than try to break it up.
Windows is offline   Reply With Quote
Old 02-11-2011, 05:53 PM   #3
ltd
Rewards Points: 536
i mean who knows .depending on the colors ,it might look good .remember its only paint you can always go back.
ltd is offline   Reply With Quote
Old 02-12-2011, 07:58 PM   #4
Workaholic's Avatar
If you have good colors it will look good.
Sean
Workaholic is offline   Reply With Quote
Old 02-13-2011, 09:33 AM   #5
not so sure it will look good. If it were me, I would remove the bead board below the chair rail or vice versa. Just my opinion.
NewEnglandYank is offline   Reply With Quote
Old 02-14-2011, 06:17 PM   #6
Workaholic's Avatar
I have run into bead board under the chair rail only not entire wall and when bead board and chair rail are properly prepped and finished with the trim paint it all looks good. If your bead board is not tore up you should be fine, only thing that may look a bit not right is the rest of the wall that you are wanting to finish with the wall color.
Sean
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Beadboard on balcony Cecosugi Building & Construction 3 09-16-2009 03:00 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
