Old 03-25-2008, 01:16 AM   #1
Q about painting stained wood
I have some ceiling beams that are stained black right now that I want to paint white. I've had a couple painters over for estimates and I'm confused about what they are telling me. One said that there would be a lot of prep involved. The beams have to be sanded and then primed, then painted. Another says that he might lightly sand them but then he would just spray with an oil based primer before painting and that will stick just fine. Which is correct? The prices are very different, and I have no idea if someone is giving me the run around or if the other guy is trying to cheap out (as the one who wants to do all the prep is suggesting). Any advice?
Thanks!
Corcoran1 is offline   Reply With Quote
Old 03-25-2008, 05:08 AM   #2
Prep is 87% of painting. Sand/oil prime/sand/then top coat IMO would be the way to go.
mark942 is offline   Reply With Quote
Old 03-25-2008, 06:06 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
They are describing the same thing
They are just doing it differently
An oil based primer is correct
I'd be wary of spraying in an occupied house, but that's just me
slickshift is offline   Reply With Quote
Old 03-25-2008, 02:29 PM   #4
OK, that's good to know. The one just seemed a lot more involved. I'm not living there yet, so hopefully the spray will be no problem. Thanks!
Old 03-27-2008, 02:33 PM   #5
Paint Contractor
This is difficult to call because nobody can see what you really have. There is nothing wrong with spraying as long as everything is protected. Sanding lightly is all that is needed. I have sprayed before but using an HVLP sprayer which is meant for things just like that. HVLP sprayer is the type of sprayer used for furniture,High Volume Low Pressure. Very little paint over spray.
I just did an article on how to paint wood paneling in my blog and the process is the same but minus the deglossing unless your beams have a gloss to them.
Just like painting wood paneling you will have to prime the stained wood with a stain kill primer first. Then once that has been done you can paint them whatever you want.
movado is offline   Reply With Quote
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 09:18 PM
Painting pressure treated wood Crackers Building & Construction 1 08-27-2007 11:51 AM
Painting Over Wood Paneling vomtickie Painting 8 08-01-2007 05:07 PM
Repairing the wood for painting bofusmosby Painting 4 06-17-2007 12:55 AM
Painting exterior wood house parasailing Painting 1 02-06-2006 02:24 PM
