Pvc Trim/bead Board Questions - Painting - DIY Chatroom Home Improvement Forum
Old 12-31-2008, 09:28 PM   #1
Rewards Points: 264
pvc trim/bead board questions
We installed PVC bead planks and trim in a mud room/laundry room.
What should we use to clean it prior to painting?
What caulk is recommended for the seams and nail holes?
What primer should we use?
7echo is offline   Reply With Quote
Old 12-31-2008, 09:38 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i use fantastic or spray 9 to clean
i would recommend a polyurethane caulk.You should use the primer recommended by the paint manufacturer,some say no priming is necessary
sw recommends A100 oil primer acrylic topcoat
Tom Struble is offline   Reply With Quote
Woodpecker Pounding My Rake Board!! mikebal Roofing/Siding 11 10-03-2014 10:59 AM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 08:43 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
