PVA Primer As A Vapor Barrier - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-04-2012, 10:01 AM   #16
Matthewt1970's Avatar
Rewards Points: 1,098
You should never try and rely on paint for a vapor barrier. If you get a crack in a corner or along the floor line or ceiling, bye bye vapor barrier.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 05-04-2012, 05:41 PM   #17
Rubbin walls since'79
Brushjockey's Avatar
I think the HO actually had no idea what they were asking for, or why.
And Nail hasn't been back to clarify.
And the county has it wrong. But that's gov't work for ya.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-05-2012, 04:02 PM   #18
Registered User
Rewards Points: 4,924
WA State has own Energy Code. Walls require interior (warm side) vapor retarder or X" exterior foamboard. Sounds like the OP didn't use the paper-faced insulation and needed/found an acceptable replacement- post #13.
Vapor barriers (area weighed) can have holes, air barriers cannot; http://www.greenbuildingadvisor.com/...cience-podcast
Gary
Old 05-05-2012, 07:55 PM   #19
Rewards Points: 626
Gary
The home owner did their own insulation. And as such I asked him about it but he told me the inspector said to use PVA primer on the dry wall and all would be good. That is Code for Washington state. two coats
Nailbags is offline   Reply With Quote
Old 05-06-2012, 12:12 AM   #20
Registered User
LOL, I was answering post #17 and 16, stating to read your post number 13...... Sorry, I should have said the OP's homeowner needed a vapor retarder as is stated in #13.
Sounds as if you are a neighbor of mine, you'll like these, Nailbags;
http://www.energy.wsu.edu/Documents/...ers%201-10.pdf
https://docs.google.com/viewer?a=v&q...B0OzT5oKmAygdg
http://www.dsireusa.org/incentives/i...srp=1&state=WA
Gary
Old 05-07-2012, 07:47 AM   #21
Rewards Points: 394
A vapor barrier primer is classified as a primer with a perm rating of under 1.0. This prevents moisture or water vapor from interior rooms from penetrating walls into the rafters (which forms mold). Glidden Professional 1060-1200 is one of these primers, and it is a polymer/acrylic blend. It has a perm rating of .6.
Will22 is offline   Reply With Quote
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 12:48 PM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 07:29 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
