-   -   Putty or Spackle for stair rail and latex chip/peel repair. (http://www.diychatroom.com/f4/putty-spackle-stair-rail-latex-chip-peel-repair-143219/)
RickDel 05-09-2012 11:32 AM
2 Attachment(s)
Hello, I've been baffled by this for a couple weeks and would like some advice.
I have four stair handrails I'm preparing for painting. They all have two coats or latex over a coat of primer. I attempted to sand them down, but the latex heated up and started to peel back. I stripped two rails to the bare wood, one rail sanded cleanly without stripping, and one sanded well over 3/4's of the rail, but the top layer of latex peeled back in a 6" spot. (ATTACHMENT Photo 1)
So, what do you recomment to repair this 6" shallow imperfection where the paint peeled/chipped back??? I experemented with some M H Readypatch spackle and it looks and feels smooth as glass; however, I'm not sure the spackle will hold up under the latex on this type of surface.
I also have some Crawford's Putty, but that stuff is a little harder to apply and I'm not sure I can thin it to the 1/32th depth of the missing latex I've peeled away.
Additionally, there's another spot on my stairs that does appear to have been repaired with spackle. It's showed up when I stripped the paint off. It seems to have held up well under the paint so far, but now that it's exposed it crumbles away when I scratch it with my fingernail. (ATTACHMENT Photo 2)
So if the answer to my first question is to use to spackle, my second question is, can I just put new spackle over the old spackle to repair the gouges and cuts I created when stripping the paint off?
Thanks!!
RickDel 05-11-2012 02:15 PM
Bump.....
pucks101 05-14-2012 10:11 PM
I say if you're having success with the M & H, keep using it. 2nd question, I say yes, if the area you think was previously spackled is solid, no problem going over it again. If it's weak or damaged, sand it out first.
RickDel 05-14-2012 10:12 PM
pucks101 - Thanks!
