Putty & Poly - Painting - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 08:40 AM   #1
Rewards Points: 150
Putty & Poly
No, those aren't turtle names (tho they sound like they could be!)
So I was about to putty my window boxes' nail holes... and I decided to [gasp!] read the directions -- the putty said to apply ~after~ stain and topcoat. That sounds crazy. Putty after you poly everything? I'd think you'd want your poly to go over the top of the putty and create one solid smooth surface. Is putty even going to bond to a poly'd surface?
Why would putty be the last thing you do? Do most ppl do it this way or am I right to think putty first and then poly, sand, poly?
-mike
SquishyBall is offline   Reply With Quote
Old 05-01-2013, 08:57 AM   #2
Too Short? Cut it Again!
Depends on the putty. Some of the colored ones have a resin in them so, in theory do not need a top coat and the fnish may not adhere. Some have a paste wax in them that, again, will block adhesion. The idea is to buff to match the sheen of your finish.
Most plain old fashioned fillers get stained with the rest and top coated with poly or whatever with the rest of the job.
Squeaky Floors-Wood Putty for Hardwood Floors that are Finished?Help HandyFrank Flooring 7 12-15-2012 08:37 AM
hazy scratches on poly finished wood fourx Flooring 3 11-19-2012 02:41 PM
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 08:29 AM
Stain over Poly? megkatgre Flooring 3 04-27-2010 01:07 PM
Window Glazing - hairline cracks bill3752 Painting 3 10-04-2008 12:15 AM
