PT Staining - Painting - DIY Chatroom Home Improvement Forum
Old 10-11-2007, 12:39 PM   #1
PT Staining
Am commencing a project but will not finish til next summer, shutting down when it gets to cold. If I wait to stain until all done, will the stain be uniform or will the different times exposed to the weather affect the intake of stain? This is in PA. Thanks.
jgpa is offline   Reply With Quote
Old 10-11-2007, 03:03 PM   #2
Deck Staining Pro
bigchaz's Avatar
You will see a difference in color where the stain has weathered for a season. It could be very minor or could be a huge color shift from UV damage to a poor quality stain. You will also have to re clean and reprep the areas that don't get stained this year.
If there is no way to get it all done at once, I would shoot for doing something like all the rails this year or all the floor boards. Not sure how your deck is made up, but don't try and stain half the railings and half the floor. One or the other will be less noticeable if the stain decides to change on you.
Also keep in mind that with stain constantly being reformatted to fit environmental (VOC) laws, if you buy the stain at different times, you risk getting something completely different, even if the label remains the same
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Old 10-11-2007, 03:08 PM   #3
Thanks Charlie.
I was actually contemplating no finish at all until completed and was wonder if the wood would take the stain in varying rates depending on the total exposure time of the substrate.
Maybe a simple water repellent until completed and ready for staining?
Old 10-11-2007, 06:04 PM   #4
Rewards Points: 506
If by "PT" you mean Pressure Treated lumber, I'd think it could safely wait until you can get it all done at once. In any case, PT lumber is quite "wet" when brand-new, and not a good surface for staining anyway.
SirWired
sirwired is offline   Reply With Quote
Old 10-12-2007, 02:52 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
You'll run into the problem you expressed concerns about (1/2 staining different)
Best to leave the PT to season
Not ideal, I know
Needs a few months anyway
It's Pressure Treated....it'll be OK
slickshift is offline   Reply With Quote
hardiplank staining Katherine Painting 11 06-25-2012 02:08 PM
Staining a garage floor? Ledge General DIY Discussions 5 07-10-2007 03:57 PM
acid staining concrete? trying-austin Flooring 1 02-18-2007 10:42 AM
staining on aluminum siding gerlawson Painting 2 09-24-2006 10:17 AM
Staining problems.. Cricketsz28 Painting 5 04-22-2006 09:36 AM
