-   -   protecting pressure treated lumber from the elements (http://www.diychatroom.com/f4/protecting-pressure-treated-lumber-elements-163132/)
Dantro 11-12-2012 07:30 PM
recently built our pergola out of pressure treated lumber, what is the correct process for seal or stain? better stains? have to be done annually? maybe some helpful facts on finishing the wood properly?
user1007 11-12-2012 09:46 PM
First, chances are you will have to wait at least 6 months to put any finish on pressure treated wood unless the treatment was a type that can be finished immediately. Check with the supplier. You will just be wasting your money and potentially causing problems if you race the process.
Since it has not been finished before, when it is time, I would stain it. Your options range from semi-transparent stains to solid stains. Semi-transparents preserve some of the existing color and most all of the wood grain variations. On the other end of the spectrum, solid stains will leave the wood grain texture but will be opaque like paint. People are probably getting tired of me posting this but it provides a nice visual explanation.
http://img2-3.timeinc.net/toh/i/g/10...-stains-04.jpg
The argument is getting harder but I preferred solvent based semi-transparent or even semi-solid stains. If you live somewhere where solvent based products are hard to buy, you will probably do alright with waterbased stains. I think when you get to solid stains you are better off with a good acrylic product like Sherwin Williams Woodscapes. Woodscapes can be tinted to any color like paint and the acrylic provides excellent colorfastness. Ben Moore makes a comparable product but it is fairly new and I never used it even though I used their paint more than others. Make sure you use a product with nice UV protection built into the formula!
You could also use a quality primer and paint but with solid stains what they are and your ability to match any color, it doesn't make alot of sense in my opinion.
As for how often? There are lots of variables starting with just the kind of weather it is going to be subjected to on a regular basis. If you use a good paint store product over properly prepped surfaces you might get 3-5 years out of an application. I usually advised folks to plan on 2-3. If they got more great, if not they were prepared.
Do avoid wax based sealing products like Thompson's Water Seal. Use will come to haunt you.
joecaption 11-12-2012 09:51 PM
And make sure to lay a tarp down on the deck before stain. You have no idea how many people want to know to go back and fix the deck after dripping stain all over it.
Gymschu 11-13-2012 06:48 AM
You really can't get any better advice than Sdsester gave. Spot on! Through many years of trial and lots of error, I have found that Flood Co's CWF-UV is a very good clear sealer. You can buy it in different tones such as cedar and redwood to get that deep cedar or redwood look. Woodscapes is a very good solid stain system which gives you hundreds of different colors to choose from. On a pergola, I would say you are going to get a good 3-4 years before recoating. If you were doing a deck, you would be lucky to get 2 years.
As for the process, I would simply coat with a roller and brush. The roller will push the material into the wood giving you a better finish. You can brush it out to push it into the wood even more.
Dantro 11-27-2012 12:30 PM
thanks for the advice, any numbers on moisture meter to look for? hoping to go with a natural finish.
