Protecting Deck - Painting - DIY Chatroom Home Improvement Forum
Old 06-15-2007, 02:06 PM   #1
protecting deck
I have been using TSP substitute + a some bleach to clean the wood siding on my house prior to painting.
I need suggestions on how to protect my deck. I tested the product on an area, and even if I wash it off immediately, it will remove some stain (and it might possibly damage the wood, too?). Even if I cover the entire deck with plastic, some of the TSP substitute might get under the plastic. The boards nearest the house, where the water runs off, will be the hardest to protect.
Is there a different product that I should use? FYI The house has heavy chalking, but little mildew.
firsthomegal is offline   Reply With Quote
Old 06-15-2007, 02:33 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
With no mildew, you should be OK to leave out the bleach
The TSP shouldn't be in enough concentration to affect the deck
(of course, test it first)
slickshift is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
