Pros Tricks For Painting Around Door Hardware.. - Painting - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 05:32 PM   #1
Rewards Points: 179
pros tricks for painting around door hardware..
okay, what are the tricks for painting around door hardware? obvioulsy taking the handle off is the easiest.. but you're not taking the hindges OUT of the door jambs are you? how do you paint around the hindges? Is it all just cut-in work? or are you wiping clean with a cloth?
there has to be a trick i don't know about.
windowguy is offline   Reply With Quote
Old 09-08-2009, 07:15 PM   #2
Remove all door hardware...For door hinges just cut in, practice ,practice, if you need to tape hinges that's fine . Just take a razor and cut the out side edge of the hinge to remove the extra tape. or if you don't want to take the time to use tape, then if you get any paint on the hinge, just wrap a clean rag around the edge of a putty knife , and wipe any paint off hinge. But really there isn't any real tricks, just a lot of practice . Or you can replace hinges with old ones.Then when you are done painting and paint is dry ,put your new hinges back on.
LouLewyLewis is offline   Reply With Quote
Old 09-08-2009, 09:43 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
It is al cut in work. Wipe off only crashes. Start with a light load on the brush at don't start right next to the hardware with a loaded brush. Discharge some of right near the hardware and then move to the hardware.
Old 09-10-2009, 01:24 PM   #4
paint
Also make sure the brush you're using is in good shape and doesn't have bristles that are starting to stray off to the side. Those will kill any paint job, but particularly tight spaces.
Allison1888 is offline   Reply With Quote
