Proper Way To Repair Oversized Outlet Hole In Drywall - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 12:31 PM   #16
Rewards Points: 518
I cut up and shove fiberglass mesh tape into the hole, fill with fast set joint compound to give it some structural packing+backing. Once dry, I then tape over the area with another piece of tape like I normally would patch with if necessary, recoat, sand and feather until happy. Never had an issue and doing it this way prevents the tape from sagging in while trying to patch.
n0c7 is offline   Reply With Quote
Old 06-24-2010, 11:09 AM   #17
Would this fix a box work on finished drywall, paint and everything. I want to change to a 'designer' outlet cover. It is too small. Found this out after I painted. What to do?
quitecontrary is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
drywall repair around an outlet. Slatherd Drywall & Plaster 7 03-16-2010 05:14 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 09:57 AM
