Proper Way To Repair Oversized Outlet Hole In Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 04-05-2008, 05:42 PM   #1
Proper way to repair oversized outlet hole in drywall
I run into this often enough to post about it:
Say you have an electrical outlet that was cut out too big (meaning hole in drywall too big). Besides buying a larger outlet cover, what is the correct way to fix this? If you just smush some joint compound in there, it really has no backing and usually hangs on by the edge, and breaks off very easily.
Same question apples to oversized vent cutouts, lights...etc.
Plasmech is offline   Reply With Quote
Old 04-05-2008, 05:50 PM   #2
Outlet patches:
http://www.all-wall.com/acatalog/info_SFOP20.html
Other patches:
http://www.all-wall.com/acatalog/Drywall_Patches.php
jerryh3 is offline   Reply With Quote
Old 04-05-2008, 08:02 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You could also consider installing oversize cover plates.
- Build Well -
Old 04-05-2008, 08:14 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 846
Or you could flat tape it w/ paper tape. (Light coat of mud (3"wide x 5"high) next to the problem area , lay paper tape in the mud (edge of paper covering miscut), wipe vertically, let dry, sand edges if needed, Lightly mud over tape going a little wider this time , let dry, and sand. Ready for prime and paint.
Sir MixAlot is offline   Reply With Quote
Old 04-05-2008, 09:07 PM   #5
Right. But some of my problems are larger than big plates lol. This builder was a real um...character.
Old 04-05-2008, 09:38 PM   #6
Electrician
Not really, its actually a code violation to have more that 1/8 gap around an outlet box... (312.4 added to the 2005 NEC)
chris75 is offline   Reply With Quote
Old 04-05-2008, 10:09 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Cut out a hole, 1/2 stud to 1/2 stud, inclusive of bad outlet hole
Cut proper size patch from good drywall piece
Cut out an outlet hole, in the proper place, in the patch
Install patch using drywall screws
Tape
Mud
Mud
Mud
Sand
Dust
Prime
Paint
or
Got to Paint Store
Get Drywall Patch Clips
Cut out a hole, slightly smaller than the method above, inclusive of bad outlet hole
Install patch using drywall patch clips
Tape
Mud
Mud
Mud
Sand
Dust
Prime
Paint
Sorry if it seems like a lot but that's the deal
Your "character" really left you a "few inches" problem that takes "a few feet" of fixing
slickshift is offline   Reply With Quote
Old 04-05-2008, 10:13 PM   #8
EXACTLY. People do not understand how a seemingly harmless simple mistake can lead to hours and hours of repairs.
Old 04-05-2008, 10:38 PM   #9
Custom Cabinet Maker
Skin the bilders *ss and use his hide to patch with
skymaster is offline   Reply With Quote
The Following User Says Thank You to skymaster For This Useful Post:
jlhaslip (03-16-2010)
Old 04-06-2008, 02:55 PM   #10
This is the best idea yet. I am in the process of painting the interior of my house. I am working room by room and am spending on average one week preping. The drywallers decided to not nail the drywall into the corners and then they taped and finished it with the corners bowing out. Once a little pressure is applied in the corner, the tape pops. I have had to cut away 6 corners and redo them in 4 rooms so far.
steel is offline   Reply With Quote
Old 04-06-2008, 03:01 PM   #11
Electrician
No drywall inspection?
Old 04-06-2008, 08:16 PM   #12
I go with the drywall patch. You just need a little piece in there to make it work.
Allison1888 is offline   Reply With Quote
Old 04-06-2008, 08:42 PM   #13
It certainly doesn't seem like there was. The house was built in '79 and I'm not sure how they did inspections back then. As much as this drywall moves around, I can't imagine it would ever pass.
Old 04-06-2008, 08:52 PM   #14
in michigan there is no inspection for drywall installation, your builder should be using reputable subs
jason h is offline   Reply With Quote
Old 04-06-2008, 09:10 PM   #15
Rewards Points: 85
Plas,
I've got a similar problem with outlets, where the "ears" on the electrical outlets when screwed into the box are not resting on drywall, thus recessing the outlet further into the electrical box and not flush with the surrounding drywall. What I did was first pull the electrical outlet out of electrical box and stuff the box with newspaper. Then I used SETTING COMPOUND and drywall knives to add onto the existing drywall around the box opening. Later I put on a second coat this time with ready-mix compound and after a day went over that area with a sponge to smooth out the drywall compound.
After this I then pulled out the newspaper I had in the electrical box.
Now you'd be ready to dab on some primer paint on the new drywall.
Best of luck with the project, rredogg
rredogg is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
drywall repair around an outlet. Slatherd Drywall & Plaster 7 03-16-2010 06:14 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 10:57 AM
