-   -   Proper way to back brush (http://www.diychatroom.com/f4/proper-way-back-brush-38444/)
bluefitness 02-16-2009 07:44 AM
I decided to use a roller on rough sawn plywood siding. I have heard of painters back rolling. Do I need to back brush the paint? Here is the procedure I have been using so far.
-cut in around battens
-apply paint with roller
-Use a 3 or 4 in brush to go over the area I just rolled. I do not load the brush with more paint. I first go in horizontal strokes and then finish off with a light vertical stroke
I sometimes I roll and back brush first and then cut in the trim
I reason I'm asking is because i noticed a splotchy area that I painted. It almost looks like it doesn't match the rest of the panel. I may have just tried to touch up the area after it had dried. This may have given an extra coat in a single spot. I'm was using Duration paint on an 80 degree day and it was drying really fast.
DGideon 02-17-2009 09:34 PM
Back Brushing
Duration is a nasty animal in the heat. In hot/humid days make sure you use a conditioner such as floetral. If the area you are painting is rough cut material then I wouldn't try to back brush. It should level out enough. Roll it on then roll on.
