Old 03-08-2011, 02:39 PM   #1
Product to go over drywall that is not smooth
I just took down paneling in a room and, behind it is in drywall. There are black glue marks along with nail holes and other imperfections. Other than that, the drywall is in good shape. I know there is a product out there that I can use that would cover all these imperfections but I don't know where to begin to look. Help? Thoughts? Brands recommended? Thanks.
CGreene is offline   Reply With Quote
Old 03-08-2011, 02:48 PM   #2
Gymschu's Avatar
Joint compound. Just thin it down a bit, trowel or roll it on, smooth it with an 8 - 12 inch drywall knife, let dry, lightly sand and repeat the process until you cover all imperfections & get your walls smooth again. Of course it helps to get as much glue, etc off the walls first so you don't have to apply more than 2 coats of joint compound.
Old 03-08-2011, 03:09 PM   #3
I was thinking of some sort of paint product that is very rough - like a stucco or popcorn type....does that make sense?
Old 03-08-2011, 04:06 PM   #4
Gymschu's Avatar
CGreene, sure, there are many textured paint products on the market from every major paint co. that you just roll on like regular paint. You can still go the joint compound route & stucco it in any type of design you want.
using Lowes edge precision flooring Andy McDonald Flooring 68 03-17-2012 02:42 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 06:23 PM
Best product to smooth rough concrete wall? jeff29715 Building & Construction 1 05-11-2009 12:34 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
